4 Way Switch Setup With Multiple Runs Of Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 12:38 PM   #16
joed's Avatar
Rewards Points: 12,416
I would eliminate the junction box and just run the fixture cable into one of the switches.
Old 03-28-2012, 12:44 PM   #17
Originally Posted by hammerlane View Post
I dont know if this helps but it has incoming power at your switch "B" which is a 3-way. Switch "A" is the 4-way and switch "C" is the other 3-way.
Al cables between switches are 12-3, all cables between lights are 12-2. In the strategically placed junction box I do not show it but the white traveler from switch "C" should be reidentified with black tape at both ends
Wow - thanks! I agree with everything except unfortuneately I cannot run wire over, through, around or under the beam. Bad planning on my part - I should've had the engineer figure in a couple of chase holes in the steel I-beam, especially at the ends (or even notches) where it has support. I will have to run down a wall into the basement and up the wall on the other side of the beam. That is only an extra 20' of wire each time I have to do that.
I think Joed commented he might break this into separate switch circuits. I originally had it designed that way but after we framed out the rooms we realized that the "small" space really functions as one room and there isn't a reason to have separetely lit areas. Then everytime we head upstairs at night we we will always have to walk to the "far" door to turn them off. You are right in that it is easier to wire but I think the initial effort is worth the end result.
CapeCod153 is offline   Reply With Quote
Old 03-28-2012, 12:45 PM   #18
Rewards Points: 2,516
Which switch would you recommend running the fixture cable out of?
hammerlane is offline   Reply With Quote
Old 03-28-2012, 12:54 PM   #19
I agree (i think). I can simply run the line continuously into the basement and back up to include the other recessed lights. So basically I would run switched power into a light and fork from there. The only reason I can think of for a junction box is if the light box doesn't have enough room for three 12/2 wires (1 coming in and 2 going out in addition to the light wires).
Old 03-28-2012, 12:54 PM   #20
Double posted
Old 03-28-2012, 01:06 PM   #21
Lets see
4 way switch setup with multiple runs of lights-4-way-11-can-lites-2-no-j-box.jpg
Old 03-28-2012, 01:11 PM   #22
Licensed Pro
Makes no sense to run the fixture wires out of anywhere but switch "C".
Is the room finished? If not, just drop the wires down through the top plate, across studs to the other side of the beam, then back up through the plate.
Old 03-28-2012, 01:42 PM   #23
The room is not finished so I can easily do as you state. And I agree that
- power in at switch B with 14/2 as 3way (junction box or pigtail off to outside lights before switch),
- connect with 14/3 to switch A as 4way,
- connect with 14/3 to Switch C as 3way, and
- run 14/2 from switch C to all lights in series (if that is what it is called).
Seems to be the simplest and easiest way for a novice electrical DIYer.
Old 03-28-2012, 02:27 PM   #24
joed's Avatar
It doesn't matter which switch you run the lights from, but all the lights need to run from the same switch.
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Single Switch with Two 3-ways to Control 2 Separate Sets of Lights? LowlyDIYer Electrical 2 10-19-2011 09:11 AM
How to wire multiple lights in attic on same circuit? bottlerockett Electrical 25 06-04-2011 04:27 PM
Wiring a switch to rope lights DK75 Electrical 5 12-02-2010 07:49 AM
Wire Multiple Lights controlled by 4-way Switch? mfleming Electrical 17 11-20-2008 08:46 AM
