Old 01-15-2013, 09:21 AM   #1
4 way switch problems plz help odd sounds
I've been having problems with a 4 way switch. Last year the switch went bad and it was a old light switch which had mercury in it that went everywhere. It was hooked up with two black wires on one side and to red on the other. I bought a new 15 amp switch and hooked it up the same way. All is good all light switches work. But after a month I started to notice when I flipped the switch it made a buzz or and arch sound and the light flickered. So I bought another and replaced it. Hooked up same way.( since all light switches worked I figured this was correct) after 6 months I noticed same thing is happening. I also noticed that the switch itself wiggles side to side. And that is when the sound happens and light flicker. Is this a problem of bad switches? Wrong hook up? Cheap switches paid $15 at ace)? Or what I have no idea whats happeing here. Help would be appreciated thanks.
bwavem is offline   Reply With Quote
Old 01-15-2013, 09:31 AM   #2
Someone's going to need to know the total watts your trying to run off of that switch.
Old 01-15-2013, 09:41 AM   #3
The switches control just the top of 3 outlets and all that us plugged into them out let's are two lamps with those new curled light bulbs.
Old 01-15-2013, 09:50 AM   #4
A loose connection or a bad/worn out switch.
You are hearing the arcing sound because there is an arc.
Most modern switches will arc if you intentially hold the toggle halfway.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-15-2013, 10:00 AM   #5
So you think it's all hooked up correct? Just bad switch or loose connection
Old 01-16-2013, 09:00 AM   #6
I never had any problems with the original switch and I lived there for 5 years until I put these new light bulbs (pigtail) cfl bulbs in. After I did 2 months later the first switch went bad. Does anyone think maybe the bulbs could be cause damage to the switches?
Old 01-16-2013, 09:10 AM   #7
These are just reguler toggle switches, not dimmers, right?
Should have no effect on a toggle.
Old 01-16-2013, 09:19 AM   #8
Just regular switches
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Problems with dimmer switch BandE Electrical 7 10-16-2012 01:38 PM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
