4 Way Switch Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 09:11 PM   #1
4 way switch problems
I need a wiring diagram showing the power, light, and a 3 way switch in one box then going to the 4 way and then finally going to the 3 way.
Thanks in advance.
mbruckman is offline   Reply With Quote
Old 03-02-2009, 09:20 PM   #2
Thanks in advance.
They are about halfway down this long article
http://en.wikipedia.org/wiki/Switch
Old 03-03-2009, 08:39 AM   #3
joed's Avatar
Rewards Points: 13,358
I think this might be the one you need. If not go here and find the one you need. There are 12 different options shown there.
http://www.selfhelpandmore.com/switch-outlet/4-way/
Old 03-03-2009, 08:47 AM   #4
That's it!
Thanks...
Old 03-03-2009, 12:57 PM   #5
If you have to troubleshoot, watch out for phantom voltages on the travelers. Don't use a neon tester for this task.
All these switches form a composite single-pole single-throw switch so if your power and load are connected correctly, running a wire from one end of the switch array to the other should light the bulb.
I'd get this power part working first.
Your wires colors are the only clue as to how this is wired so they have to be right.
Dimmer Switch Vandiyan Electrical 21 12-15-2008 07:23 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Dimmer Switch Problems? dmtm21 Electrical 2 08-07-2007 01:18 AM
