Old 03-18-2009, 12:09 AM   #1
4-way switch problem
I have an existing 4-way not working but supposedly did at one time. There is a 2-wire line going out to the light and a 3-wire line going on to the next switch. The white of the 2-wire goes from circuit panel to 2-wire going to light. The black from circuit goes to switch. Red and white of 3-wire go from switch on to next switch and the black from the 3-wire is wire nutted to black of 2-wire going to light. Bottom line, first switch must be on for other switches to work -- it doesn't stay hot. Any help?
judyconte is offline   Reply With Quote
Old 03-18-2009, 05:28 AM   #2
Vann
I'm not clear exactly what you have going on but look at this diagram joed posted.
sorry, but another 3 way switch question
Using the diagram should you figure out whats happening and what is supposed to be happening.
vann is offline   Reply With Quote
Old 03-18-2009, 08:15 AM   #3
Which box does the 2 wire line from the panel go to?
How many switches are there?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 03-18-2009, 08:43 AM   #4
joed's Avatar
That's only one switch of the set. The switch you are describing should be a three way not a four way.
In that box every thing sounds correct IF the black wire from the panel goes to the COMMON screw of the switch. The common screw will be black in colour or marked common.
If it still doesn't work then the switch is bad or the problem is at one of the other switches.
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 01:35 AM
combo switch problem electric1 Electrical 2 06-11-2004 11:11 AM
