4 Way Switch With One Fixture In Hallway - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 09:38 PM   #1
4 way switch with one fixture in hallway
We changed out the 3 switches in our hallway with a 4way in the middle and 3ways on the ends and it was working. Now we are trying to replace the fixture (wiring the same way as the old one) and it's not working. I have a diagram for the 4way setup, but we don't have enough wires to set it up that way. Help!
rstompkins is offline   Reply With Quote
Old 04-30-2009, 10:07 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
You need to provide us with all the wires in all the switchs and the fixture for us to help.
Old 04-30-2009, 10:13 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
So far so good
Now we are trying to replace the fixture (wiring the same way as the old one) and it's not working......Help!
Replacing the fixture is the easiest part. You went astray in part one, It was not working as it should. Here is a short tutorial:
http://www.wfu.edu/~matthews/courses/p230/switches/SwitchesTut.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-01-2009, 08:09 AM   #4
Rewards Points: 1,418
Maybe the new fixture itself was defective.
When you connect the black and white wires of the fixture the same way as the black and white wires of the old fixture, the new fixture should work for better or worse the same way.
Or maybe you took apart more wire nuts than necessary and didn't put it back together properly.
The ground wire (bare wire) must not be used as "an extra conductor". All ground wires are tied together wherever they come together with a pigtail or long end attached to the outlet box (light box, etc.) if metal and one attached to the framework of the fixture itself, and not to the white (neutral) wire(s).
Post us a diagram of what you now have.
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Help! wall light fixture w/ switch 8christiest Electrical 3 08-28-2007 04:21 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 09:43 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 07:11 PM
