4 Way Switch And Neutrals - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 09:10 PM   #1
Rewards Points: 152
4 way switch and neutrals
Since light switches now require neutrals is this wiring method still code acceptable?
Ground wire is omitted for clarity, but will be in the circuit.
http://www.diychatroom.com/attachmen...-lite-4way.jpg
n175h is offline   Reply With Quote
Old 07-14-2013, 09:51 PM   #2
" Euro " electrician
frenchelectrican's Avatar
The only two switches on the left and centre one is legit and the thrid on the right side is not legit.
The only way you can do is run from left to right all the way thru so power in left then go right to the four way switch then go the other three way switch then go to the luminaire.
That route will have netural all the way thru.
Unless you snag a XX-4 NM cable then it will be legit either way.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
n175h (07-15-2013)
Old 07-15-2013, 05:43 AM   #3
Rewards Points: 2,516
Looks like one of my diagrams.
Will the circuit function properly? Yes
Although a lot of the code deals with safety issues, the fact that there is no neutral at the right switch is in no way a safety issue.
It has to do with someone in the future adding a switch that requires a neutral like a timer, motion sensor, etc.
Would I lose sleep over no neutral there. Not, and I'm sure 90% of others would not either.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
n175h (07-15-2013)
Old 07-15-2013, 05:50 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If there is attic above, basement below, the backside of the wall is not finished, or there is drop ceiling above that 3rd switch, you do not need to include the neutral in the box.
The Following 3 Users Say Thank You to k_buz For This Useful Post:
frenchelectrican (07-15-2013), n175h (07-15-2013), stickboy1375 (07-15-2013)
Old 07-15-2013, 12:55 PM   #5
That is instering to know that part.
Merci,
Marc
n175h (07-15-2013)
Old 07-15-2013, 04:33 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Merci,
Marc
Its skipped over a lot in these threads.
The Following User Says Thank You to stickboy1375 For This Useful Post:
n175h (07-15-2013)
Old 07-15-2013, 07:12 PM   #7
Rewards Points: 152
Thanks for the replies. Didn't think it would pass the inspection. AHJ is really tough in my town. Building a new home and have to do it right. I think I can run all the way through the chain and send the power up from the end. Thanks for the helpful hint.
Old 07-15-2013, 09:49 PM   #8
E2 Electrician
Seriously doubt you are dealing with the AHJ, just an inspector with a badge that makes him feel important.
Old 07-16-2013, 04:06 PM   #9
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
If u are going to use black and red as your travelers you should use them the whole way thu as travelers...the 14/3
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
3 way light circuit, middle load, neutrals in switch box? langless28 Electrical 1 10-16-2012 09:32 PM
Single pole switch wired with two neutrals. buckybadger Electrical 2 07-26-2012 07:04 AM
Do the neutrals for a light switch need to be in the same box as the switch? kornbln Electrical 4 04-06-2009 08:23 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
