Old 06-08-2012, 11:31 AM   #1
4-way switch with multiple end of run lights
Hi. I am seeing wiring diagrams with contradictory solutions to this question. Can someone please help?
I am wiring some hall lights as follows:
Line--> 3-way switch--> 4-way switch--> 3-way switch ====> Light ====> Light ====> Light ====> Light ====> Light.
So the question is, do I need 14/3 or 14/2 Romex running between the lights? (The = in this diagram.)
To me, this is just an extended switch loop, so my thinking is I should be able to use 14/2 (The amperage of the circuit is sufficient for 14 gauge on this load). Yet some diagrams show 14/3. Others show 14/2 between the lights.
Thanks a million. I am sitting here stumped, with holes in my wall.
daviswhite is offline   Reply With Quote
Old 06-08-2012, 11:39 AM   #2
Licensed electrician
You only need xx-2 between the lights in that wiring setup. The xx-3 will need to be between the switches.
daviswhite (06-08-2012)
Old 06-08-2012, 12:39 PM   #3
joed's Avatar
14/2 is all you need.
This is not a switch loop. If it was a switch loop you would need 14/3 and the switches would be at the opposite end of the circuit from the power feed.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 06-08-2012, 01:34 PM   #4
I was not precise with my language. That's why you guys are the pro's.
Old 06-08-2012, 01:52 PM   #5
Heres something that was put together for another question on 4-way. Each switch turns on all 11 can lights.
hammerlane is offline   Reply With Quote
Old 06-08-2012, 02:46 PM   #6
The common theme, from Hammerlane's diagram, etc., is that the string of lights, no matter where it is after the third switch, feed off the common of the third switch, and their lights' neutrals splice all the way back to the white/neutral of the line-in.
That way sounds so simple. I think I have it right.
This is a great site. Thanks, everyone! I'm moving again.
Tags
4-way, electrical, wiring
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
wired new lights and now the switch turns off and on all my lights naty0629 Electrical 14 05-18-2012 01:03 PM
Multiple lights with one switch DIY Mark Electrical 1 12-03-2011 12:15 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 03:47 PM
Wiring Lights and Running Multiple Circuits in Conduit mark_anderson_u Electrical 0 11-02-2010 10:06 AM
