4-Way Switch For Light & Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 02:21 PM   #1
Hello,
Ive been searching countless threads online and have asked for help in other chatrooms and sites. I have not received or found a direct answer to how to wire these up.
I have lots of experience wiring switches, outlets, fans, lights, heaters, dryers, other household electrical items, but when it comes to wiring 4 way switches I have very little experience.
Heres the scenario.
I have a ceiling fan with light in all bedrooms. I just wired up 2 bedrooms to have a separate switch for the light and the fan on the wall with 14/3 wire. That was easy.
In the last bedroom, I want to do the same thing only have the switches in 3 locations. So 6 total switches. I believe 4 must be 3-way & 2 in the middle must be 4-way switches. I have wired from the fan 14/3 to control the light from the 3 locations, but how to I get the fan switched in the same locations? Do I need another 14-3 wire or just a 14/2 wire? Or can I use the original 14/3 that both are on it just using extra jumper wires to connect the fan switches? Not sure jumper is the correct term, I think I'm close, just want to be right. If I had a wiring diagram that would greatly help me understand what goes where.
Anyway, I thank everyone who can give any advice. Thank you.
toolmantommy is offline   Reply With Quote
Old 10-18-2011, 02:38 PM   #2
Code05's Avatar
Rewards Points: 1,104
Here ya go.
http://www.ask-the-electrician.com/4...chdiagram.html
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
toolmantommy (10-18-2011)
Old 10-18-2011, 02:57 PM   #3
Thanks. Thats was fast! I see the diagram, but thats just for a light. How about a fan/light combo? I currently have 14/3 running from the ceiling fan/light.
In that diagram there is 14/2 & 14/3 used. right now I just have 14/3 wired in for the 3 light switches and the fan is controlled by a pull chain.
I may be making this more complicated than it really is.
Old 10-18-2011, 03:40 PM   #4
Code05's Avatar
I am getting a bit confused, explain what you have and what you want to do for each room.
Old 10-18-2011, 04:53 PM   #5
Just one room.
One ceiling fan with light. I need 6 switches. 3 for the light & 3 for the fan.
Thank you.
Old 10-18-2011, 04:58 PM   #6
joed's Avatar
Rewards Points: 13,282
Where is the power feed? Fan/light? or switch box? I will make a diagram for you shortly after you answer.
The Following User Says Thank You to joed For This Useful Post:
Old 10-18-2011, 05:09 PM   #7
a switch box. Thanks!
Old 10-18-2011, 05:56 PM   #8
joed's Avatar
Here you go.Fan and light controlled separately by one switch each and by 3 switches each.
Old 10-18-2011, 06:01 PM   #9
Awesome! Thank you very much! I really appreciate it! I knew I was making it more complicated than I thought!
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
