4 Way Switch Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 12:20 PM   #1
4 way switch issues
I have one light controlled by 3 switches. I have just installed a new 4 way switch, thinking it was the problem. No difference. The switch marked common will operate the light on/off, but the other two switches will not turn the light off when turned on at the common. The other switch of the three has a slide dimmer. It will not turn the light on or off, just flickers when switched. Should I replace the common and the dimmer switch? If one before the other, which one first? The house is 6 years old and this switch arrangement has worked just fine until one day it started the problems I have described. Any advice or suggestion would be appreciated. Thanks
jcornett is offline   Reply With Quote
Old 01-05-2012, 12:29 PM   #2
MarginallyQualified
Rewards Points: 2,464
No difference.
What is the problem?
...this switch arrangement has worked just fine until one day it started the problems I have described.
I'd start by removing the dimmer device...
and tracing out the remaining continuity.
When/as you do this... take a couple of photo's and careful notes
of exactly what wire sets (2w vs 3w) are in which box connecting which device etc.
If help is still needed post back with that detail.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
jcornett (01-05-2012)
Old 01-05-2012, 12:34 PM   #3
4 way switch issues
Thanks for the advice. I will try a new dimmer.
Old 01-05-2012, 12:35 PM   #4
MarginallyQualified
I didn't say that.
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
Safety Rollout switch issues DannyV HVAC 3 02-18-2011 11:09 AM
Issues After Installing Light Switch shriekback Electrical 11 09-07-2010 10:47 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
