4. Way Switch Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 11:28 PM   #1
4. way switch help
If you install 3. switchs to controle one Light I know they go like this,.
The first switch is a 3. way swicth and the second switch is a 4. way switch and the third switch is a 3. way switch then the Light.
I would like to know in all switchs the Ground Screw is Green but is it ever Brass or anything els?
biferi is offline   Reply With Quote
Old 06-05-2012, 07:13 AM   #2
DIY staff
Rewards Points: 7,174
Should be green--but could be a different color--the grounding screw will be attached to the metal frame of the switch--
Post a picture or link to the exact switch---
Old 06-05-2012, 12:01 PM   #3
thanks but
I am not working on anything yet I just wanted to check because I thought I read somewhere that it may be Brass but that never sounbded right to me.
Old 06-05-2012, 12:52 PM   #4
Licensed electrician
Rewards Points: 1,272
The ground screw should be green or hex shaped, never brass.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
