4 Way Switch Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 09:07 PM   #1
Can any number of light circuits be placed between the switches on a 4 way circuit as long as it does not exceed the capacity of the circuit?
For example: A light between the first 3 way switch and four way switch and then 3 lights between the four way switch and second 3 way switch?
Thanks, Steve
Sierevello is offline   Reply With Quote
Old 02-02-2011, 09:14 PM   #2
Licensed electrician
Rewards Points: 1,758
Placing lights between the switches makes the wiring more complicated. It is easier to wire them from one end of the switches. Doing it the other way requires additional conductors in the cables.
Old 02-02-2011, 09:14 PM   #3
Maybe, If you are just talking about location the answer is yes, if you mean to connect the lights in between the switches the answer is no.
hayewe farm is offline   Reply With Quote
Old 02-02-2011, 09:17 PM   #4
joed's Avatar
Rewards Points: 13,308
What you are describing can be done but it will require four wire cable for parts of the circuit. It is not the standard way to do it.
Old 02-02-2011, 09:24 PM   #5
Electrical Supplier
Rewards Points: 150
Wiring a multiple location circuit in deivance to standard or common practice could lead to people getting hurt. Just make a junction at the existing light and run the circuit to the new location..
I dont understand why you would want to "put a light between switches"
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-02-2011, 10:21 PM   #6
I understand now. The lights need to be at the end of the circuit.
Thank you for the clarification.
-Steve
Old 02-03-2011, 07:14 AM   #7
Rewards Points: 1,536
Let's imagine that you are all ready to begin installing your 3 way or 4 way switch setup with lights between the switches here and there.
Start by stringing just enough wires to operate one light preferably at one end or the other end of the light sequence physically. Then add two wire cable from that light to the remaining lights. Hint: It is best to run 3 wire cable non-stop between the switch boxes. Wire the first light from one of the 3 way switches in a 4 way setup (not the 4 way switch)
Replacing manufactured home light switch to dimmer. Why 3 circuits? MikeVila Electrical 17 06-10-2012 01:12 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
