4-way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 09:07 AM   #1
Unhappy
4-way switch
Hi, I'm about to pull out more hair and hoping someone here can help me. I tried replacing an old 4-way hall switch with a dimmer - unfortunately it was a 3-way dimmer, so obviously didn't work. I couldn't find a 4-way dimmer, so bought a new 4-way switch to go back to square one (I had already thrown out the old one). I've tried all wiring options and the new 4-way won't work. I'm wondering if it is because the wiring isn't grounded and the new switch has a ground wire screw? Even if it did work, I then read that I shouldn't use the grounded switch in an ungrounded receptacle, so now feel stuck. If this is so, is there a site where I can get an old fashioned, ungrounded 4-way switch, so I can move on and forget this aggravation?
kdodge is offline   Reply With Quote
Old 09-28-2009, 09:25 AM   #2
Licensed Pro
The lack of a ground will have no effect on whether the switch works or not.
Make sure you have a 4way switch and not a two pole 240V switch... they look the same but are very different.
The 4 ways either have the travelers from switch A on one side and those from switch B on the other, or they they connect top and bottom. Most will have two screws one color and the other two another color to distinguish how the travelers should connect.
Old 09-28-2009, 09:49 AM   #3
Yes, I have the 4-way - two on each side...
Old 09-28-2009, 10:24 AM   #4
Licensed electrician
Rewards Points: 1,892
You will need to read the instructions on the box to see how to wire the pairs of travellers. Some are top/bottom, some are left/right.
Old 09-28-2009, 10:35 AM   #5
Thought they were top, bottom, but I'll try the left, right variation when I get home. Thanks.
Old 09-28-2009, 10:36 AM   #6
Oh, and thanks. Good to hear the lack of ground wire won't matter.
Old 09-28-2009, 10:54 AM   #7
Licensed Pro
The 240V two pole switch is 2 per side also, that's why I said look closely.
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
