4 Way Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 11:14 AM   #1
4 way light switch
i replaced 2-3 ways and the 4 way i wired it the same as it was the 4-way will only work in ne position .. i need help
ineedhelp67 is offline   Reply With Quote
Old 01-26-2012, 11:19 AM   #2
Julius793's Avatar
Give us pictures and a full description and then we will try.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-26-2012, 11:30 AM   #3
4-way
im usally pretty good at this stuff. it doesnt matter which way i wiring it it only works in one position . i will try to get some pics for u i tested all the switches for power it only shows power when the light is off idk
Old 01-26-2012, 11:31 AM   #4
and its an older house built in the late 70's they used black/white wiring
Old 01-26-2012, 11:46 AM   #5
Julius793's Avatar
Where is the constant power by the switch or light?
Old 01-26-2012, 11:50 AM   #6
Rewards Points: 119
Was it working prior to replacing the switches?
KStatefan is offline   Reply With Quote
Old 01-26-2012, 11:51 AM   #7
it seems to be at the light when its on but theres no power at the switches when the light is on
Old 01-26-2012, 11:52 AM   #8
i replaced one of the switches a month ago , cause it went out 3-way.. is it possbile they used 2- 4 ways so no it wasnt workng right before i replaced it
Old 01-26-2012, 11:54 AM   #9
47_47's Avatar
Rewards Points: 52
Are you sure you have a four way switch and not a double pole? A double pole will be marked on and off, while a four way will not.
47_47 is offline   Reply With Quote
Old 01-26-2012, 11:56 AM   #10
but will the double pole act like a 4-way
Old 01-26-2012, 11:57 AM   #11
my switch is a 4-way it has no on/off markings
Old 01-26-2012, 12:04 PM   #12
Julius793's Avatar
Not at all
Old 01-26-2012, 01:46 PM   #13
joed's Avatar
Rewards Points: 12,464
If you move the wires to the same location on the new switch as the old switch that might not work. Unless yo had the same brand of switch the positions could be different. It could be side to side instead of top to bottom or vice versa.
Old 01-26-2012, 02:10 PM   #14
Rewards Points: 83
It depends on which box has the power source wires. Here is a basic drawing of one way to do it.
davido30093 is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
Pilot Light Switch? dweeter Electrical 3 11-04-2011 08:44 PM
HELP.. trouble adding light to single pole switch RickDel Electrical 13 09-09-2009 10:18 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
