4 way dimmer
Does anyone make 4 way dimmer switches? I've not had any luck finding any 4 way dimmer setups.
I've seen some things call multi-location dimming controls, but am having trouble telling if they are some type of remote or what. They don't seem to be a regular 4 way from what I can tell.
Doesn't anyone make some type of digital dimmer switch setup that allows you to adjust the dimmer from 2 or more locations? I've never used dimmers from more than 1 location before. If there was a dimmer control on each physical switch, can't the switching work in the standard method that a 3/4-way setup works, with the dimmer on each switch controlling the load when that switch is active?
I can use a regular 4 way in the mix if I have to. This is for my kitchen and I have 3 entrances to the kitchen, I was thinking that I would like to have access to the dimmer at all 3 doors.
A 600 watt dimmer should be fine, as the largest load should be 6 cans with 50W halogen spots in it. No low voltage, All 120v.
Jamie
