4 Switches Control 1 Light, Power At Light - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 09:03 PM   #1
4 switches control 1 light, power at light
Please confirm the last circuit found at:
http://www.wfu.edu/~matthews/courses/p230/switches/SwitchesTut.html
Everything is physically wired like this and wound be difficult to change.
(3way)-(4way)-(fixture+power)-(4way)-(3way)
I can get lights to work, but if any switch is used to turn it off, the same switch must be used to turn it on, but one of the 3ways must be in a certain position. I have something wrong, but I double checked according to the schematic above. I get 64 volts in certain conditions across one of the 3ways.
1. Is it possible to wire 4 switches with power at the light fixture?
2. Is there a more detailed schematic available?
thinksnowjob is offline   Reply With Quote
Old 05-18-2011, 09:36 PM   #2
joed's Avatar
Rewards Points: 12,328
Your problem is the wrong wire is on the common screw of one of the three ways. In the drawing the commons are the single white on the left and the single black on the right.
The drawing you have will work fine. There is no more detail to add. There a many different configurations that this could be wired however. Power could go to any switch or the light. Light could be at any switch or between any switch.
Old 05-18-2011, 11:02 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
if you still have trouble let us know what cables/wires enter each box and we will give you further advise
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-19-2011, 06:21 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
The drawing is correct, something got wired wrong along the way, causing one of the 3way common terminals to be incorrect.
Kyle
Old 05-19-2011, 09:26 AM   #5
Rewards Points: 1,492
Caution: The terminals of 3 way and 4 way switches cannot be identified by such terms as "center right" or "top left". Usually the common terminal of a 3 way switch and the terminals of a 4 way switch (aka intermediate switch) for one cable's travelers are stained a darker color.
Old 05-19-2011, 08:55 PM   #6
Dudes! Got it! Combination of responses given. Thanks a bunch!
Two 3-way switches: one pilot light, one regular flitz Electrical 14 08-20-2012 06:46 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 06:49 PM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Extend a circuit/draw power from light Ontario Electrical 3 03-23-2010 06:41 PM
