#1 |
4 switch box for 4 lights
I am new to this and have to date only replaced a few outlets installed some fixtures. Nothing too difficult.
My question is I recently tried replacing what seemed to be an ancient set of switches that controlled 4 lights in my basement. To my surprise when I unscrewed the plate all the wires were black and the switches seemed to be from the 1800's! One of the lights was also controlled by another switch from up the stairs in the foyer. Any ideas where to start?
#2 |
Take out one switch at a time and replace it. just put the two wires from the old switch on the two screws from the new switch.
Master Electrician |
#3 |
UAW SKILLED TRADES
It also sounds as if you have a 3-way switch, you need to replace it with a 3-way switch. You need to be sure to identify the wire on the common screw of the old switch and be sure to attach it to the common screw of the new switch the other two (travelers) can go to either of the remaining two screws of the 3-way switch. The common screw is usually dark to black in color and the traveler screws are brass colored.
Stubbie |
#4 |
maybe i should explain a bit more....i will post a pic of the switches....very strange to me. Never seen any like it......
I am showing the one that had the 4 wires to it. this is the one that was the three way. three wires were in the holes and one was to the bottom of it attached to a screw. it was jumped on the other side to the other switch that did not have the three holes. Last edited by xxpinballxx; 04-26-2007 at 04:38 PM. |
#5 |
that is not one device. purhaps a switch and a light?
#6 |
Sounds like the doubled up wire is the power wire. It is feeding power to two different switches.
#7 |
well there were two of these side by side and all four were switches. Two on each bracket. only one of the four switches had the three holes. I know which wires are the power but the bad thing is they are all black wires! is there a way to test which ones are which. I guess I could to to each fixture and pull on that lights wires but this would be a real pain seeing as they are typical 50's basement fixtures that are pretty solid in the ceiling.
#8 |
for the single pole switches do not worry about which is hot and which is the switch leg. it does not matter.
for the three way. just try each wire one at a time on the point (common ) terminal. when you get the right one, the three way will work correctly.
#9 |
i'll give her a try......actually do not need the three way anymore but might try it anyways.
| Display Modes | |
| Wiring double switch for new ceiling fan | toolmanwannabe | Electrical | 17 | 11-15-2011 10:34 PM |
| Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) | inspectator | Electrical | 8 | 08-07-2007 02:19 AM |
| recessed lighting wiring to 3way switch | DIY4EVER | Electrical | 1 | 07-12-2007 02:35 PM |
| Detached garage adding a 3 way switch. | Slatherd | Electrical | 4 | 01-02-2006 03:53 PM |
| 1 switch, 3 lights? help? | bexnfx | Electrical | 5 | 09-12-2005 03:17 PM |
