4 Square Box With Round Mudring For Junction At Wall Light - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2014, 04:44 PM   #1
Rewards Points: 83
4 square box with round mudring for junction at wall light
Hi. I need to join some cables at a wall sconce/light location and want to use a 4 inch or 4-11/16 box with a round mudring. If the sconce/wall light canopy will cover the mudring is it against code not to put drywall over the mudring?
pex006 is offline   Reply With Quote
Old 05-29-2014, 05:44 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 536
That's what mudrings are made for.
The Following User Says Thank You to jbfan For This Useful Post:
pex006 (05-29-2014)
Old 05-29-2014, 08:14 PM   #3
Sparky
Rewards Points: 510
314.21 Repairing Noncombustible Surfaces. Noncombus-
tible surfaces that are broken or incomplete around boxes
employing a flush-type cover or faceplate shall be repaired
so there will be no gaps or open spaces greater than 3 mm
(1⁄8 in.) at the edge of the box.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
pex006 (05-29-2014)
Old 05-29-2014, 08:23 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
???? The OP is simply asking if drywall or other finished material is required... I say NO.
The Following User Says Thank You to stickboy1375 For This Useful Post:
pex006 (05-29-2014)
Old 05-29-2014, 08:52 PM   #5
Rewards Points: 83
The box will be in the wall and mounted to a stud. The mudring will be flush with the drywall as usually done. The drywall is already up and I have a square hole there already. I was wondering if I had to add drywall up tight to the round area of the mudring.
Old 05-29-2014, 08:58 PM   #6
Rewards Points: 480
No. Ron
ront02769 is offline   Reply With Quote
Old 05-29-2014, 09:08 PM   #7
E2 Electrician
AH, that changes everything. Yes, it must be have no larger than 1/8th gap.
Old 05-29-2014, 11:26 PM   #8
Rewards Points: 83
Ok. I'll have to do something different. Is there a square box that is made for mounting fixtures that is higher capacity. The circle mounting strap I have lines up with the holes on a four square two gang switchbox like I posted a picture of below, but the holes are 6-32 and I think they have to be 8-32. Can I tap them out to 8-32 or is that a violation for modifying a box?
Old 05-30-2014, 05:25 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Those boxes are rarely used (at least I rarely see them). Post a picture of your fixture strap because I don't think any fixture strap is made for the box you posted.
The Following User Says Thank You to k_buz For This Useful Post:
pex006 (05-30-2014)
Old 05-30-2014, 05:48 AM   #10
Licensed electrician
Rewards Points: 1,754
Wall mounted fixtures are allowed to use the 6-32 screws if they weigh less than 6 pounds and are less than certain dimensions.
If drywall is installed it must be patched to fit the box opening.
pex006 (05-30-2014)
Old 05-30-2014, 12:23 PM   #11
Rewards Points: 83
The fixture strap is just like the one in the picture below. The fixture weighs 2 pounds. Two of the screws in the box line up with two in the strap, but if you guys think it's a bad idea, I'll use the square to circle mudring and patch the drywall.
Old 05-30-2014, 12:36 PM   #12
Install a single gang plaster ring and patch around it. That will be easier to keep the mud out of the box.
pex006 (05-30-2014)
Old 06-03-2014, 01:25 PM   #13
Rewards Points: 83
Here is what I was thinking with this box and another masonry style box. Would this be acceptable?
4 square box with round mudring for junction at wall light-100_2345.jpg   4 square box with round mudring for junction at wall light-100_2346.jpg   4 square box with round mudring for junction at wall light-100_2343.jpg
Old 06-03-2014, 02:48 PM   #14
Rewards Points: 826
You had the right answer in your first post. In IL 4" square metal boxes are the norm due to EMT requirements. Mud rings on front. Your mounting plate is meant to see a round box or round mud ring. Why fight it?
Buy a bag of 20 minute powered drywall compound. Mix up a bit and fill in the gaps around the mud ring to existing drywall. Since this stuff chemically hardens it'll be rock hard in 60-90 minutes.... Also since your escutcheon plate sounds large you don't even need a perfect paintable finish to the patch. Wipe away any excess mud from drywall with a wet sponge before it hardens.
curiousB is offline   Reply With Quote
The Following User Says Thank You to curiousB For This Useful Post:
pex006 (06-03-2014)
Old 06-03-2014, 06:15 PM   #15
Rewards Points: 83
Ok. Thanks. I'll do the circle mudring and do the setting compound mud up to it. Thanks for all the replies.
Moving a wall light to the ceiling with minimal "attic" access. tomatolater Electrical 11 11-25-2012 08:11 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
How to fix Ceramic towel rack that got knocked out of the wall? There are 2 square holes now on each side to the wall? nicki3174 Kitchen & Bath Remodeling 8 11-21-2011 09:08 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 11:02 AM
