4 Prong Dryer Outlet & Breaker Installation - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 07:28 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by jbfan
The breaker is in place to protect the wiring, not the dryer!
Then why would an appliance spec a max circuit size? If what you say is true, you could wire a dryer on a 50 amp circuit if the branch circuit is appropriately wired.
Old 03-29-2012, 07:42 PM   #17
When you say "Make sure that the bonding strap is disconnected from the neutral inside the dryer" does the attached photo look correct then? I do not see a bonding strap on the neutral. However, take a look at the photo... I think it looks okay but there are two neutral wires there.
flipjarg is offline   Reply With Quote
Old 03-29-2012, 07:56 PM   #18
I=E/R
a7ecorsair's Avatar
Question: Is it permissable to have a 30 amp 120/240 receptacle on a 240V 50 amp circuit?
a7ecorsair is offline   Reply With Quote
Old 03-29-2012, 07:58 PM   #19
I=E/R
a7ecorsair's Avatar
Looks good at this end..
Old 03-29-2012, 08:01 PM   #20
Master Electrician
Rewards Points: 3,920
Thanks for the input... its nice to see two people agree. I will definitely switch the breaker to a 30amp. There was no dryer in this spot before so I wired the receptacle/outlet.
So... from what I have learned from this thread... the new picture (attached) is correct.... right?
The pictured receptacle is NOT a 30 amp dryer receptacle.
brric is offline   Reply With Quote
Old 03-29-2012, 08:17 PM   #21
k_buz's Avatar
Not unless there was supplemental protection specifically for that recept
Old 03-29-2012, 09:01 PM   #22
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
The wire clamp does not look right on the back of the dryer.
Looks like the lock screws are the only thing holding that cable from falling into the back of the dryer.
sublime2 is offline   Reply With Quote
Old 03-29-2012, 09:26 PM   #23
Licensed electrician
Rewards Points: 1,770
That is a Tomic connector. Looks fine to me.
Old 03-29-2012, 10:44 PM   #24
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Those clamps work fine. Sometimes when replacing a cord I have to use a romex connector because the previous person did not install the one that came with it. They must just toss it out thinking it's a spare part.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Tags
4 prong , dryer , ground
Dryer - 4 prong to 3 prong majorwest Electrical 15 02-06-2012 05:03 AM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
New electric dryer install trips breaker cortell Electrical 8 08-29-2011 09:09 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 10:45 PM
