4 Prong 220v Recep. To A 3 Prong - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 03:07 PM   #1
4 prong 220v recep. to a 3 prong
I have a 4 prong 220v outlet in my garage and would like to convert it to a 3 prong outlet for my welder and compressor.
Do I just put a wire nut on the neutral and tuck it back in the box? Then install the new 3 prong outlet using the two hots and ground?
Thanks.
mopowers is offline   Reply With Quote
Old 08-18-2009, 03:29 PM   #2
300zx's Avatar
Post
Thanks.
Yes you can do that
300zx is offline   Reply With Quote
Old 08-18-2009, 04:09 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,928
Originally Posted by 300zx View Post
Yes you can do that
Not necessarily. What, exactly, does the poster mean by "three prong" versus "four prong"? The original "four prong" installation contains two hots, a neutral, and a ground. Now, what does the new equipment require? If it is two hots and a ground, then he can do as you suggest. However, if it is two hots and a combined neutral/ground (an old-fashioned range or dryer connection) then your suggestion is not compliant - it would use the grounding conductor to carry current. He would need to keep the existing receptacle and swap cords on the equipment.
In any event, I would suggest changing plugs/cords instead of the receptacle. A four-wire receptacle is more useful and versatile than three-wire, and you can install a matching plug on any piece of equipment.
mpoulton is offline   Reply With Quote
Old 08-18-2009, 04:45 PM   #4
300zx's Avatar
Post
A 3 wire comp 220 needs 2 hots and a ground same as welder.Swaping out cords where are you going to putNeutral Wire on the device? I dont know do whatever you want to do.
Old 08-18-2009, 04:58 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Maybe I missing your point.. the poster said what he is wanting to connect a 240 volt welder and a 240 volt compressor. why would you want to change the factory cords that are 3 wire to 4 wire cords.....
Simply cap the neutral and wire up the new receptacles that match the factory cords.
Only thing we should be concerned about after that is the correct ocpd and wire size in the branch circuit if he intends to change from one tool to the other. Connecting both to the same branch circuit may not work out but it might be fine just depends.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-18-2009, 05:27 PM   #6
Originally Posted by Stubbie View Post
Maybe I missing your point.. the poster said what he is wanting to connect a 240 volt welder and a 240 volt compressor. why would you want to change the factor cords that are 3 wire to 4 wire cords.....
I'm not sure if I understand all that 'ocpd talk.'
Maybe I should clarify my question a little.
When my house was built, I had them run a 220 circuit into my garage so I could use my welder and compressor (off the same outlet, but at different times). Instead of putting a 3 prong outlet, the electrician put a 50 amp circuit with a 4 prong outlet. He also used what looks like very large aluminum wire. Iím not sure what gauge. I think he mustíve thought I was going to have another oven/stove or something in my garage.
I just want to replace the 4 prong outlet with a 3 prong one so I can run my tools as I intended. In order to do so, I believe I can just cap the neutral and wire up the two hots and ground in the new 3-prong receptacle. Is this correct? Does it matter what side the two hots are in on the new receptacle??
Old 08-18-2009, 05:39 PM   #7
300zx's Avatar
Post
Does it matter what side the two hots are in on the new receptacle?? No dosn't matter. very large aluminum wire sure its not coper wire Alum will be hard to conect also use some Nolox or similar and it wont corrode
Old 08-18-2009, 05:40 PM   #8
I'll take a picture tonight...
Thanks for your help!
Old 08-18-2009, 05:53 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
You have got the right solution... No it doesn't matter which brass screw the hots connect to on the receptacle.
Sorry about the OCPD slang that's just an over-current protection device or circuit breaker.
As for using both from the same receptacle at different times you would need to give us the electrical specifications of the tools and what plug is on them. It appears the electrician ran a 50 amp circuit to that original 4 wire receptacle. So probably a 50 amp double pole breaker and #4 al cable maybe 6.
The wire size is is fine but may be too large for the new receptacle to accept just have to see and make pigtails if necessary.
The tools are both 240 volt and cord and plug from the factory?? If so and both have the same plug on them then they can be ran from the same branch circuit at different times....that's probably obvious.....
Stubbie
Old 05-03-2012, 09:50 AM   #10
220V 3 vs 4 wires
I have a similar situation needing clarification.
I have a single phase China built Two Value Capacitor Asynchronous Motor Type YL90- 2 driving a small hammer mill.
I have a dryer 4 prong plug in my shop and want to connect a dryer cord to my hammer mill motor with a three wire cable. I have purchased a dryer plug and cable that fits the 220V receptacle and now I need to know which wires do I use to splice the four wire to the three wire?
Now moving down the cable to the motor connection there seems to be two options. Which option do I use? see attached diag.
Greatly appreciate your assistance.
Martin
wildblue09 is offline   Reply With Quote
Old 05-03-2012, 09:55 AM   #11
Licensed electrician
Rewards Points: 1,506
The connection diagram show the option to change from clockwise to counter-clockwise rotation.
Is your mill a straight 240 volt unit?
wildblue09 (05-03-2012)
Old 05-03-2012, 10:07 AM   #12
220V 3 vs 4 wires
Thank you for your prompt response.
Witch way is which looking at the motor? Do you determine cw or ccw looking at the shaft end of the motor?
I have single phase 2.2 kw 220V 50 hz 13A 2800 rpm
See: http://www.mfrbee.com/product/125008...ous_Motor.html
Also the dryer plug cable has four conductors.... coloured Red Black White and Copper ground wire.
The hammer mill cable has three conductors ... coloured Green Black and White...
I assume the black goes to black, white goes to white and green goes to copper... Whats up with red?
Thx
Martin
Old 05-03-2012, 06:39 PM   #13
hammermill termination block
it looks like the jumper tabs are configured to run ccw. Now which coloured wire goes where?
Thx
martin
4 prong 220v recep. to a 3 prong-img00226-20120503-0410.jpg   4 prong 220v recep. to a 3 prong-img00227-20120503-0411.jpg
Please help, changing dryer cord from 3 prong to 4 prong oldpirate Electrical 8 08-10-2008 04:42 PM
220V Wiring Mdbuilder Electrical 18 07-10-2008 11:14 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
3 prong 4 prong 240 ranges. K2eoj Electrical 1 11-21-2005 06:39 AM
