4" Pot Light Clearance - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2009, 02:19 PM   #1
HABSFAN2006's Avatar
Rewards Points: 150
4" pot light clearance
I want to install some old pot lights in my basement remodel.
They are 4" with a rating of 75w max par 30, my question is, what is the minimum clearance for electrical cables passing around this pot light?
Where i would need it to be centered, there are 4 x 14-2 cables passing over this pot light, and I can maintain 4" clearance, is this enough?
Also, I am 20" away from the rigid gas line, which is 1.25 ips steel,
I am guessing this should be plenty also?
Aprreciate your input!
HABSFAN2006 is offline   Reply With Quote
Old 04-11-2009, 02:34 PM   #2
Remodeling Contractor
you will be fine. Clearance needs to be 2" minimum.
Old 04-11-2009, 02:35 PM   #3
Union Electrician
goose134's Avatar
Should be fine.
goose134 is offline   Reply With Quote
Old 04-11-2009, 07:02 PM   #4
Rewards Points: 150
Bob, that's great, thanks for the input.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
