4 Lamps On A 2 To 1 Ballast Conversion - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 11:31 PM   #1
4 lamps on a 2 to 1 ballast conversion
Hey Folks
My 4 kitchen tubes were dim/flickering so I went to the local home improvement store and bought replacements. I don't recall my original bulbs but the replacements I ended up with were F34 t12's. Plugged them in and they were just as weak as the old ones.
Went back to the store and was sold a ballast (Phillips REB-4P32-SC) that is supposed to take the place of my two 12 year old ballasts (LUMI-KON R-240-120-CP).
I basically wired the new ballast in a parallel fashion compared to how the previous ballasts were wired. I know that’s an oversimplification and might not make too much sense. Just trying to avoid uploading wiring diagrams if possible.
The problem is only two bulbs work at a time and only if they are installed in pairs(both on the same side, both on the 'inside', or both on the 'outside'). They do not illuminate if they are installed in a staggered manner(one on the outside of one side with the other bulb installed in the inside of the other side).
As I look on the box of my new ballast, it says "for F17, F25, or T8 lamps". Are my T12 bulbs my problem?
thanks
columbiawifi is offline   Reply With Quote
Old 07-07-2012, 12:48 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The bulbs are not the problem in this situation...however...you will burn out that ballast much quicker. You have to use the lamps the ballast is made for.
I am looking for the diagrams.
Old 07-07-2012, 12:54 AM   #3
k_buz's Avatar
It appears that your old ballast required each of the pins to have leads. You tie both the leads coming off the socket together then follow the wiring diagram on the new ballast.
Old 07-07-2012, 01:54 PM   #4
I think I'm with you. I might jot down something and post it, just to make sure I'm good.. and there wont be any post-4th of July fireworks. (I'm a DC guy..AC scares me. )
Old 07-07-2012, 03:36 PM   #5
MarginallyQualified
Rewards Points: 2,464
the new ballasts should have a diagram on them.
(some even have lines drawn with pretty colors)
Follow the directions on YOUR ballasts.
Old 07-07-2012, 04:17 PM   #6
liscenced electrician
Rewards Points: 538
It's the voltage that your thinking of. DC is actually worse than AC. DC will make a bigger explosion if everything else is equal
jimmy21 is offline   Reply With Quote
Old 07-08-2012, 10:49 AM   #7
I think I understand now. One thing that was throwing me was the fixture’s wiring. The outside lamps were connected to each other (one side) as were the inside lamps. Didn’t occur to me that I would need to snip that connection to account for the new ballast’s wiring.
The new ballast does not have a 4 bulb application wiring diagram, but I located it on the manufacturer’s site.
Thanks again for all the replies.
Old 07-08-2012, 11:19 AM   #8
MarginallyQualified
Didn’t occur to me that I would need to snip that connection...
You got it.
Help replacing T12 Ballast hugocraft Electrical 36 12-21-2012 04:16 PM
T12 to T8 fluorescent conversion? rjniles Electrical 28 08-18-2011 09:39 AM
2 ballast to 1 ballast for 4 lamps HJR Electrical 7 07-12-2011 07:24 AM
T12 ballast to T8 c.bustle Electrical 5 07-10-2011 11:33 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 05:02 AM
