-   -   4 Gang Box AND Two Plugs? (http://www.diychatroom.com/f18/4-gang-box-two-plugs-167033/)
Jackwood185 12-20-2012 09:02 PM
Hey everybody. First post here. I searched prior to posting a thread to no avail. I have a very basic understanding of electrical. Have replaced receptacles, light fixtures etc. but i'm in the middle of wiring a new bathroom added in the basement. Here's a breakdown of what it consists of.
One switch: Controlling one pot above a shower.
One (Dimmer) switch: Controlling one pot in the middle of the room.
One (Dimmer) switch: Controlling two sconces above a sink.
One switch: Controlling a fan.
There is power coming in directly from the fuse box to this 4 gang box. Now what I'm not sure about is, CAN I WIRE TWO PLUGS to this box's power. One GFI near the sink, and one on another wall for other accessories.
To add to the problem, we want to hard wire a towel heater somehow. But have no idea if that will involve the 4 gang or not. Also, I'm not sure if this is getting to be too much for one...power. Our fuse panel is maxed out as is but we were hoping to get this done before having to upgrade to a bigger panel as it will cost us around $1000-1500.
Thanks in advance!
frenchelectrican 12-20-2012 09:18 PM
That is not bad arrangment. see below for more comments.
As long this is the only circuit for this bathroom it is not a issue at all also it have to be 12 AWG ( 20 amp circuit ) and if you do use deep 4 gang box the wirefill useally not a issue as long you keep it neat.
Thanks in advance!
The other thing all the receptales in the bathroom it have to be GFCI'ed there is no extempts on them.
As far for the towel heater that useally 200 to 300 watts range but few are lower on wattage rating so check the nameplate for the actual info also some will have it own thermosat or switch if not then you will have to install a switch next to it ( I rather use the timer for this purpose for safety reason )
Hope that help the infomation ya looking for.
Merci,
Marc
hammerlane 12-20-2012 09:19 PM
1 Attachment(s)
Not a good start to do a complete wire of a bathroom.
You can put plugs into receptacles. You cannot under any code wire plugs directly into a box's power.
frenchelectrican 12-20-2012 09:25 PM
Thanks in advance!
To clear up the confusion here as Hammer lane post the photo which I do understand your statement saying plugs which I know you are saying two receptales to the box's power which that is the 4 gang switch box that is common to do that as long it is own circuit to the bathroom.
Merci,
Marc
Jackwood185 12-20-2012 09:31 PM
Thank you! I sell myself short. I have a moderate understanding of electrical. Installing pot lights and sconces with jumper wires and fans is simple. I was just unclear if I could also have two receptacles as well. (Not inside the box...In there own boxes.) Yes, I definitely meant receptacles and not plug as that makes no sense. The bathroom is on it's own circuit. Thanks again guys!
sublime2 12-20-2012 09:37 PM
Wow! You acknowledge his lack of knowledge and them admonish him for his terminology.
Little harsh with that I think.
Jackwood185 12-20-2012 10:57 PM
^^Haha, I thought so. If anyone has the time to actually explain this confusing wiring though that would be amazing. I'll have to re run the two cables I have for the receptacles as they're 12/2 and need to be 12/3, correct? I'm unsure of which and what will be pig-tailed.
mpoulton 12-20-2012 11:24 PM
12/2 is correct for the receptacles. Just run 12/2 NM from the 4-gang box to the first receptacle location, and then from that receptacle to the next one. Connect the cable going to the first receptacle directly to the cable coming from your panel. White to white; black to black. Of course all four switches are also connected to the black wires, and all of the neutrals and grounds are connected too. At the first receptacle location, install a GFCI. Wire the power source to the LINE terminals, and the outgoing cable to the second receptacle on the LOAD terminals. The second receptacle does not need to be a GFCI, since it is protected by the first one.
Jackwood185 12-20-2012 11:27 PM
Thank you so much!
mpoulton 12-20-2012 11:32 PM
As far as the actual mechanics of making these connections in that box, I think the easiest way would be to connect all four switches along one piece of black wire, stripping small sections of insulation where the wire connects to the screw terminal. This lets you connect three black wires together (incoming from panel, outgoing to receptacles, and switch power) rather than six (four switches plus incoming and outgoing). All six neutrals and ground will need to be connected though, and the easiest way to accomplish this would be push-in connectors. If you don't like those, you'll have to use at least two wire nuts with jumpers between them because you're not fitting 6 #12's in one nut in that box, even if the blue ones technically allow it.
Jackwood185 12-20-2012 11:37 PM
You've been so helpful. This should be a breeze. Thank you thank you.
hammerlane 12-21-2012 07:46 AM
I was not feeling good last night. Did not take my medication. I really laugh when people refer to receptacles as sockets.
frenchelectrican 12-21-2012 09:44 PM
Don't be too suprised what the Europeans will call the receptacles as socket or power point either word is very common over here.
Just give you a head up with it.
Merci,
Marc
