4 Cans & 3 Switches - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 01:22 PM   #16
If the circuit in the diagrams has four lights at 100W I calculated the current at 100W*4/110V = ~3.5A, correct?
And if correct is there any reason why I can't run 14/3 wire through the switches and 14/2 from the last switch to the lights?
ecommerceaustin is offline   Reply With Quote
Old 02-06-2013, 05:18 PM   #17
joed's Avatar
Rewards Points: 11,576
#14 cable is only permitted on a 15 amp circuit. If this circuit is on a 15 amp breaker then you can use #14 cable.
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 01:37 PM
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 01:01 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 04:21 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
