4/0 4/0 2/0 Aluminum - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2007, 11:04 PM   #1
Can I use 4/0 4/0 2/0 Aluminum wire from my meter to my service panel for a 200 amp service? It will be in 2 “conduit at a length of 50’
jbrock04 is offline   Reply With Quote
Old 05-27-2007, 06:40 AM   #2
You have the correct size wire for a 200 amp service, but I need to wonder how you are going such a long distance from meter to panel.
A typical meter would be on the outside of the house just under or over the service drop or lateral. The main panel would be right near the meter, in the same enclosure as the meter, or just inside the house right where the service enterance conductors enter the house.
In order to run the service conductors a long distance between meter and main panel, the conductors must stay outside the home and enter at a point nearest the meter.
Master Electrician
jwhite is offline   Reply With Quote
Old 05-27-2007, 09:15 AM   #3
Its a new modular home. The sleeve in the basement is on the side of the house and they were to drop the service panel there, but instead they dropped it by the front door. I was going to run my conduit from the sleeve over to the panel inside. Does this sound ok? Also thanks for the help.
Old 05-27-2007, 09:31 AM   #4
Kitchen remodel Guru
A.W. Davis's Avatar
If I where you I'd upsize the 2" conduit!
A.W. Davis is offline   Reply With Quote
Old 05-27-2007, 10:18 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
No. You cannot be that far into the house with the unfused service cable. You either need to have a main disconnect outside (or immediately inside), or run the service cable around the outside of the house to right where the main panel is.
Are you doing this yourself or having an electrician doing it?
Old 05-27-2007, 10:18 AM   #6
Why?.....
Old 05-27-2007, 10:23 AM   #7
A.W. Davis's Avatar
Originally Posted by Speedy Petey View Post
Why?.....
....why not?
Old 05-27-2007, 11:36 PM   #8
im not sure if its the same where you are but in washington the rule is fifteen feet of unfused service feeders.
-gooch
gooch is offline   Reply With Quote
Old 05-28-2007, 12:31 PM   #9
15 feet?!? That is about the longest I have seen allowed.
Old 05-28-2007, 04:22 PM   #10
Yes I'm doing it myself. I have a 200 amp disconnect, it is required if you can not go direct into the service panel
Old 05-28-2007, 04:33 PM   #11
Master Electrician
JohnJ0906's Avatar
After the service disconnect, you will need 4 wires - hot, hot, neutral, ground.
If I am correct about what you are doing- meter to disconnect outside, from disconnect to inside of house to panel. The 4/0, 4/0, 2/0 will be OK from meter to disconnect, but not afterwards.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Shredding Aluminum Cans bobo General DIY Discussions 36 11-10-2009 02:32 PM
Aluminum Door sill and Concrete Dragon Building & Construction 2 01-06-2007 12:55 PM
Coil Aluminum murray11 General DIY Discussions 2 06-17-2006 12:42 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
