-   -   3way wiring problem (diagram inside) (http://www.diychatroom.com/f18/3way-wiring-problem-diagram-inside-25325/)
jelly 08-17-2008 08:31 AM
101 Attachment(s)
Good day, Below is my wiring diagram I am having problems with.
Can you help me pair the blue letters and numbers?
I am confident with my connections at the switch leg and at the lighting fixture. I need help where the feed comes in to the first switch. This first switch is a lutron 3 way dimmer with 2 reds and one black wire.
The only pair I am certain of is connecting 2 and 3 (neutrals)
Thanks for your help.
joed 08-17-2008 08:49 AM
F1-B
F2-L3
A-L1
B-L2
B is the common connection on the dimmer.
jelly 08-17-2008 09:12 AM
101 Attachment(s)
Thanks for your response joe. I lucked out and have it hooked up like this and it is working!
I guess it doesnt matter whether I follow your direction or mine below? Thx again
F1-B
F2-L3
A-L2
C-L1
SD515 08-17-2008 10:17 AM
General 3 way switch wiring: The neutral of the source goes directly to the load. The 'hot' (black) of the source goes to the common terminal of one of the 3 way switches. The 'black' of the load goes to the common terminal of the other 3 way switch. The 2 remaining travelers get hooked up to the remaining terminals on the 3 way switches. Doesn't matter which wire on which terminal. That's general wiring of a 3 way switch leg.
Using the illustration you provided:
Switch box 1: having a 14/2 (source) and a 14/3 (going to the fixture) and the dimmer switch in box 1
14/2 white to 14/3 white (this will be your neutral)
14/2 black to black wire of dimmer
14/3 black to one of the red wires of the dimmer
14/3 red to other red wire of the dimmer
Switch box 2: having a 14/3 going to the fixture and a standard 3 way switch
14/3 black to common terminal
14/3 red to traveler terminal (either one)
14/3 white (taped black to show it's an ungrounded [hot] wire now) to other traveler terminal.
Fixture box: having a 14/3 coming from switch box 1 and a 14/3 coming from switch box 2
14/3 coming from switch box 1:
white to white of fixture (this is your neutral)
black to white of 14/3 coming from switch box 2. (white of switch box 2 again being taped black to show it's an ungrounded 'hot' wire)
red to 14/3 red of switch box 2
That leaves the black from switch box 2 and the black of the fixture left to deal with...and those 2 get connected together.
I see that you have posted now that it is working. Looks like both your way and joe's way are correct. Except joe said "B-L2" and I think he meant "C-L2", as 'B' would already have been connected to the incoming feed.
jelly 08-17-2008 11:40 AM
101 Attachment(s)
Thanks SD515!
I am going to file your explanation away for future reference.
Much appreciated.
joed 08-17-2008 08:15 PM
Mine is actually wrong. The last direction should be C-L1 not B-L1. A and C can be reversed with no problems.
