3WAY Switch Options - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 04:30 PM   #16
Licensed electrician
Rewards Points: 1,788
The MWBC in that case is considered one circuit.
Old 05-23-2013, 05:07 PM   #17
joed's Avatar
Rewards Points: 13,354
To make the lights work you will have to give up one circuit.Bring the two cables into the switch boxes at both locations. Bring the feed into the switch box in the house.
At the three way in the house, Connect the hot from the power feed to the common screw and the black power feed cable tot he shed. Connect the power feed white tot he shed feed white. Run power to the shed on one of the cables. Use the second cable to bring the travellers to the shed.
At the shed connect the incoming travellers to the switch. Connect the common of the switch to the power going to the light. Use the neutral from the power feed cable to complete the light circuit.
Old 05-23-2013, 06:04 PM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,396
Originally Posted by Seattle2k View Post
You linked to your PC's local drive. Attach images, by clicking the "Insert Image" button.
Lot of interesting stuff on there... Could I get a copy of your movie "Trailer Park Cutie"??
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 05-23-2013, 06:09 PM   #19
Rewards Points: 744
Seattle2k is offline   Reply With Quote
3way switch and 4 way switch rich4343 Electrical 16 04-02-2012 10:10 AM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
split recptacle w/duplex recptacle to 3way switch HELP yeller Electrical 4 06-29-2010 09:41 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
