3WAY Switch Options - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 12:15 PM   #1
3WAY Switch options
Hello all! I have used this message board to help me put together a nice starter home but i never went beyond what i felt comfortable doing on my own (paid electrician to upgrade panel to 200a) or without at least speaking to a pro first. With that said, I'm hoping someone out there can help me with my situation. I built a 12x20 shed, dug a trench and ran 2 - 12/2 UG lines from my house to the shed. This was done so i could have a few outlets and a couple lights in the shed. PROBLEM IS now i was hoping to add an exterior light onto the shed using 2 separate locations to turn it on/off (one at exit door of house and another at exit door of shed). I know in order to do this i should of used 12/3 wire because of the travelers but I'm an idiot and didn't think about this prior. is there ANY other way i can make this happen with my current setup? also, the exit of the house is a full unfinished basement so there are no restrictions from or to the electrical panel at all. i made a picture to help explain my situation a little better. ANY advice is greatly appreciated and thank you in advance!
met416 is offline   Reply With Quote
Old 05-23-2013, 12:22 PM   #2
[img]C:\Documents and Settings\US Test-Dave Wright\Desktop[/img]
Old 05-23-2013, 12:54 PM   #3
Rewards Points: 744
You linked to your PC's local drive. Attach images, by clicking the "Insert Image" button.
If you want to use 3-way switching configuration, you need to have the travelers. Maybe there's a wireless solution.
Seattle2k is offline   Reply With Quote
Old 05-23-2013, 12:55 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
You can't post images from your computer.
They need to be hosted on a site like photobucket or flickr.
Old 05-23-2013, 12:56 PM   #5
jbfan's Avatar
Rewards Points: 424
Like seattle said, wireless.
Old 05-23-2013, 12:56 PM   #6
Licensed electrician
Rewards Points: 1,506
Also you can only have one feed to your outbuilding. You said you had 2 cables running out there.
jbfan (05-23-2013)
Old 05-23-2013, 01:22 PM   #7
Philly Master's Avatar
Rewards Points: 516
i think that has to do with services ....
230.2 Number of Services
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-23-2013, 01:44 PM   #8
Nope, but thanks for playing.
II. Buildings or Other Structures Supplied by a
Feeder(s) or Branch Circuit(s)
225.30 Number of Supplies.
A building or other structure
that is served by a branch circuit or feeder on the load side
of a service disconnecting means shall be supplied by only
one feeder or branch circuit unless permitted in 225.30(A)
through (E). For the purpose of this section, a multiwire
branch circuit shall be considered a single circuit.
Where a branch circuit or feeder originates in these
additional buildings or other structures, only one feeder or
branch circuit shall be permitted to supply power back to
the original building or structure, unless permitted in
225.30(A) through (E).
For the purpose of this section, a multiwire branch circuit
Old 05-23-2013, 02:01 PM   #9
Rewards Points: 516
LMAO you'll love this one .....
(D) Different Characteristics. Additional feeders or branch circuits shall be permitted for different voltages, frequencies, or phases or for different uses, such as control of outside lighting from multiple locations.
Old 05-23-2013, 03:17 PM   #10
Kind of hard to do on a single phase system. Also we are not mixing something like a 277/480 and a 120/240 volt feeders. Try again.
stickboy1375 (05-23-2013)
Old 05-23-2013, 03:36 PM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Are you sure you're an electrician?
Old 05-23-2013, 03:40 PM   #12
Almost have to give points for effort.
Old 05-23-2013, 04:06 PM   #13
Rewards Points: 516
I wad just funning ... I could not help myself... And cracked myself u
You are coorect ...
Old 05-23-2013, 04:27 PM   #14
Electrical Enthusiast
Rewards Points: 504
Out of curiosity, would it be code-acceptable to put both circuits on a double pole breaker ?
Kyle_in_rure is offline   Reply With Quote
Old 05-23-2013, 04:28 PM   #15
E2 Electrician
You are allowed to run a multi wire branch circuit to a separate structure, meaning, instead of running (2) 12-2 UF's, he technically could have run a single 12-3 UF and been code compliant.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Philly Master (05-23-2013)
3way switch and 4 way switch rich4343 Electrical 16 04-02-2012 10:10 AM
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
split recptacle w/duplex recptacle to 3way switch HELP yeller Electrical 4 06-29-2010 09:41 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
