3way Switch Oops! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 01:28 AM   #1
3way switch oops!
Ok ... So drywall is up and wondering if I can salvage this without tearing into everything. So here's what I have:
Power into 3 way switch
14-3 wire to fixture 1
14-3 wire to fixture 2 (oops)
14-3 wire to 3 way switch
With that setup, I basically have only 1 neutral to work with ... Which means I have only one fixture I can make happy and work. Any idea how I can make fixture 2 light up?
Other info ... 15A service on a regular breaker. However... All devices around this are new and on AFCI... so no sharing of the neutrals.
Shaotzu is offline   Reply With Quote
Old 06-13-2011, 02:46 AM   #2
Rewards Points: 512
Right, you just needed a 2-wire between the lights. So, ignore the RED wire between the lights - it won't be connected at either end.
Old 06-13-2011, 02:49 AM   #3
Rewards Points: 512
You will just need a pigtail (6" piece of white wire) from the White Neutral entering the first lamp to the second lamp.
Old 06-13-2011, 02:56 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Let me get this correct the power to first three way switch then luminaire *1 then luminare*2 then three way switch ??
If so then it will not really work at all the only way it will work the best is if you take first three way and run 14-3 to the other three way switch then from there you can keep the exsting cable then the luminaires will work that way.
(My prefered way is start at the first three way switch which you have power then run the shuttle conductors { travellers } to second three way switch then run to the luminaires this is about the best way you can do it and plus what more it each switch box location you will have legit netural at switch box { this will be in effect with 2011 NEC code cycle only when your state will adopt it }
Otherwise you will have to bring out 14-2 between the luminaires for the shuttle conductors I will have to find a drawing somehow.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Shaotzu (06-13-2011)
Old 06-13-2011, 03:58 AM   #5
That's my problem... I can't get a neutral ran from lamp 1 to lamp 2.
It's kind of what I figured though ... I need some way to get a neutral into lamp 2.
Old 06-13-2011, 04:03 AM   #6
Merci,
Marc
Marc,
I prefer power into switches first and then running the power out to the fixtures too. It makes life so much easier! Unfortunately, this one didn't really work out this way and I made the mistake of running only one 14/3 between the fixtures instead of two 14/2s... So now I'm short a neutral!
One question... The end of the run (last switch) is in a box with other switches and neutrals from a different lighting circuit. Not ideal, but if that wasn't on an AFCI breaker, could I tie into a neutral there and run back to my second lamp? (that run I can make)
Old 06-13-2011, 07:44 AM   #7
joed's Avatar
Rewards Points: 12,416
You can not tie into a neutral from a different circuit. It would not work even if you could. You still need three wires for the switch and then a fourth wire for the neutral.
There is only one way to fix this. You must pull a new cable. It could be between the fixtures or between the switches.
The Following User Says Thank You to joed For This Useful Post:
Old 06-13-2011, 08:04 AM   #8
I=E/R
a7ecorsair's Avatar
Is this the path of the cables too?
You only need one neutral but you need two travelers between the switches.
Can you make one fixture work so it is controlled by both switches?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 06-13-2011, 08:11 AM   #9
Yes... This is the cable path as well. And I have no problem getting one light to work ... Just can't get both.
Old 06-13-2011, 08:13 AM   #10
I=E/R
a7ecorsair's Avatar
Do you have access to the attic so you can get to the fixture boxes? If so, add a 14-2 between the boxes. That should give you what you need.
Old 06-13-2011, 08:33 AM   #11
Rewards Points: 1,494
Do they make a wireless 3 way switch kit? This way you can send raw hot power to the remote switch (#2) using the black wires, send switched power from the load switch (#1) to the lights using the red wire, (and white for neutral).
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-13-2011, 08:45 AM   #12
Unfortunately no. It's a wall sconce in a stairwell and then another one in the basement on the wall. attic is no help.
Old 06-13-2011, 09:04 AM   #13
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
You could use www.X10.com modules.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Old 06-13-2011, 09:12 AM   #14
I=E/R
a7ecorsair's Avatar
Originally Posted by electures View Post
You could use X10 modules.
This is a useless link...............
Old 06-13-2011, 09:35 AM   #15
electures's Avatar
Try again.
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 10:14 PM
split recptacle w/duplex recptacle to 3way switch HELP yeller Electrical 4 06-29-2010 09:41 AM
Switch now controls large area... froddan Electrical 5 12-06-2009 10:04 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
