3way Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2007, 10:49 PM   #16
Rewards Points: 93
Very good thread! I just re-wired my 3 way today and was getting 60v~ and thought i had things upside down. Sure enough i searched here and found the answer.
I also think the length of the 14-3 determines how much induced voltage you will have. My home is an older one and for some odd reason, they ran the wires to the basement then back to the 2nd floor for the 2 way . I must have about 40 feet of wire for a 3 way switchin system 10 feet apart.
Either way, good post and just wanted to chim im...
simonb is offline   Reply With Quote
Old 09-04-2007, 08:30 AM   #17
Master Electrician
JohnJ0906's Avatar
Originally Posted by sootybuttercup View Post
A tip for anyone using their body as a voltage tester...use 2 fingers on the same hand and make sure no other part of your body is touching anything that may be grounded (wet floor, copper pipe, neutral wire, etc). The last thing you want is voltage passing through your heart (if you grabbed a wire in each hand, or were standing on a wet floor in regular shoes). I'm not recommending "human voltage testers" but, like any other dangerous thing, there is a right way and a wrong way...if you insist on doing it.
Although you do point out that voltage passing through the heart is very bad, NEVER EVER use your body as a tester!!!!!!
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 09-05-2007, 05:20 PM   #18
Electrician philosopher
I have a problem with a 3-way switch in the master bedroom. When one switch is shut off the other will not work to turn it on. It seems to go in both directions. I will use the link to try and fix it when I am brave enough to mess with electricity some day. Water, close quarters and even heights don't scare me, but honestly I am scared of anything with a wire. I always check the breaker 2 or 3 times before touching anything LOL.[/quote]
You've swapped one of your travellers with your common. I do this for a living and I did this same thing just today
Andy in ATL is offline   Reply With Quote
Old 09-08-2007, 10:28 AM   #19
can you give file repai sytem electrical home . email sogoku@yahoo.com.vn . thank you
spk53 is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
