3way Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 09:10 AM   #1
Rewards Points: 16
3way question
Is it possible to do a 3way switch with lights coming off each switch?
I have power coming into the basement switch and 4 pot lights down there. The other switch is in the kitchen. There is a stairwell light and wires go into the kitchen switch already. 3way wire will go between the switches. Appreciate e help
Andrew
cornation71 is offline   Reply With Quote
Old 06-22-2013, 10:13 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Nope. Not without some serious re-wiring.
It is MUCH easier to just run a wire from one light to the other.
Old 06-22-2013, 10:19 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,450
Coronation....
I'm sure Speedy is dead right.... but I don't really understand your question and present wiring.... (Speedy... I couldn't understand it)
You might define it better... just in case we are misunderstanding....
Then of course it may (probably) just be me
MTN REMODEL LLC is online now   Reply With Quote
Old 06-22-2013, 10:36 AM   #4
Resi EC
Rewards Points: 252
Are the lights on the same circuit?
Anything is possible .... with the right amount on the check
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
MTN REMODEL LLC (06-22-2013)
Old 06-22-2013, 11:30 AM   #5
Rewards Points: 16
The basement is unfinished. I have fished the 3way wire from one switch to the other. I just asked because there is already a wire from the kitchen switch to the stairwell light.
I wanted to try and avoid going from the basement light to the stairwell since its more involved, but I guess it's easier like you said to keep the lights in series.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
