3way Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 11:44 AM   #1
3way lighting
I have 2 3way switches with a light in the middle. Switch #1 has feed. Is it possible to add a receptacle after switch #2? Is there a constant hot in that box to tap off of?
Rhyno973 is offline   Reply With Quote
Old 10-08-2010, 11:53 AM   #2
Just call me Andrew
Rewards Points: 1,020
You probably don't have a neutral in that box, unless you have 4 wires in it.
I assume you only have 3 wires in the second switch box, and they are all connected to the switch? If this is the case, then unfortunately you will need to find another power source for your outlet.
Andrew
secutanudu is offline   Reply With Quote
Old 10-08-2010, 12:16 PM   #3
I don't have a neutral. I have a white that is relabeled black, a red and a black
Old 10-08-2010, 12:24 PM   #4
Just call me Andrew
Not possible then
Andrew
Tags
3way , lighting circuit
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 03:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 01:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 09:06 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
