3way Half Switched Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2010, 09:36 AM   #1
3way half switched receptacles
I have 2 3way switches and 5 receptacles thereafter. I want the 5 receptacles to b half switched and half constant. I have the feed coming into switch#1 and then a 3 wire w/Ground goin to switch#2 then 3wire w/ground goin to the receptacles thereafter. How can I wire this to have the receptacles half switched half constant by the 2 3way switches? Thanks ryan
Rhyno973 is offline   Reply With Quote
Old 10-05-2010, 09:44 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Sorry, can not do with existing wiring. You need a hot supply at the second switch box or at one of the receptacles.
In you existing set up, the hot is in the first switch box and is connected to the common of the 3 way switch. If you can run another cable from switch 1 to switch 2, then it will work.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 10-05-2010, 03:33 PM   #3
joed's Avatar
Rewards Points: 12,018
RJNILES is correct. You would need a four wire feed between the switches to make it work.
You could do it by bringing power to the second switch or the first receptacle instead of the first switch.
Tags
3way , receptacles , switched
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
How to Wire Two Switched Receptacles Avanzi Electrical 7 06-06-2010 09:13 PM
Rewiring - adding receptacles, paths to use RST Electrical 2 03-14-2010 03:29 PM
Maximum number of receptacles on 15 amp circuit flati Electrical 11 03-07-2010 09:08 AM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 11:49 AM
