3D Design Final - Need Help ASAP - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 10:42 AM   #1
3D Design Final - Need help ASAP
Okay guys, sorry for the bold topic, but I'm in the middle of finals, I have a 3D project due at the end of next week, and I need some serious help. For my project I need to cut some small detailed foam buildings. I tried a lot of methods and finally have come down to building a foam cutter. There are plenty of tutorials online, but I'm stuck.
The design is super simple, I have a metal ring with wire attached. The wire runs through a wood board, then wraps around a nail underneath.
I bought a 18/24 volt power adapter, stripped the end and took the positive and negative ends, put alligator clips on, and attached them to the ring, and the nail.
It heats the wire. Problem is, it heats it way too much. The wire was getting red hot in a few seconds.
So I bought a 12/9/7.5/6/5/3/1.5 volt adapter. Stripped the ends. Did the same thing, however, when I tried connecting the adapter to my rig, It was starting to work, but the adapter would shut off after going over 6 volts. I need more power to cut the foam.
Anyone have any ideas?
I tried taking apart some of the adapter maybe I take out some device inside the circuit board of the adapter? No idea what that would be.
HunterT is offline   Reply With Quote
Old 04-23-2011, 12:57 PM   #2
Rewards Points: 1,522
How about:
http://www.acehardware.com/product/i...ductId=1297973
or
http://www.lowes.com/pd_123251-273-S...ler%20Electric
bob22 is offline   Reply With Quote
Old 04-24-2011, 12:44 AM   #3
You can not hook a wire directly to the output of a transformer, it creates a short circuit and over heats. You need a rheostat in the circuit. The easiest way is to get a model train transformer with a built in rheostat and dial.
hayewe farm is offline   Reply With Quote
How To Check A Steel Carport Design abrogard Building & Construction 8 10-05-2010 04:59 AM
Final Inspection Questions docmattman Building & Construction 6 07-15-2010 08:11 PM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
Final inspections rocketdoctor Remodeling 8 03-24-2009 07:18 AM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 10:48 PM
