38 Volt On A Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 10:23 AM   #1
dcm
38 volt on a plug
I bought a bank repo house which had been rewired before I bought it. I found a plug controled by a wall light switch. (two plug outlet split) with the switch off I get 38 volts from the plug, with the switch on I get 120 volts ? any ideas ?
dcm is offline   Reply With Quote
Old 11-28-2009, 10:29 AM   #2
Licensed electrician
Rewards Points: 1,766
I will bet that you are using a digital meter. You are reading phantom voltage. It is not a problem, the meters are too sensitive and do not place enough load on the circuit. A solenoid type meter would not show this voltage.
Old 11-28-2009, 10:30 AM   #3
joed's Avatar
Rewards Points: 13,322
There is no problem. The plug is switching on/off. You are using a digital meter and the reading is called phantom voltage. Plug a lamp in and measure again with the lamp switch turned on.
Old 11-28-2009, 10:31 AM   #4
dcm
yes your right im using a dig. meter thanks.
Old 11-28-2009, 11:03 AM   #5
Almost all analog/dig/neon/non-contact testers will show phantom voltages. The meters' high input impedance is the problem when using these to test house wiring. That's why they invented Wiggys and Low-Z meters.
Old 11-28-2009, 04:38 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Test it out with an incad bulb to see if it lights up. Probably wont, does sound like phantom voltage, but always good to double check anyway.
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 09:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 07:44 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
