320Amp Double Lug Meter - (2) 200amp Panels - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 03:30 PM   #31
1texasguy's Avatar
Thanks again brric,
That is what I thought and that it how I wired. I started doubting myself when looking at the pic above but it appears that they may have done it that way also.....as they should have.
You've been great help and patient -a class act - thank you.
1texasguy is offline   Reply With Quote
Old 07-15-2011, 10:47 AM   #32
1texasguy's Avatar
Update -
320A meter installed, installed 200A panel in the shop, inspector green carded the install with a comment that this was one of the most professional installs he has seen, POCO ran underground service and I now have power with nothing catching fire and no deaths.
Thanks to the many who helped me clarify and made input.......the time you took to respond is greatly appreciated.
http://imageshack.us/photo/my-images...ectrical7.jpg/
http://imageshack.us/photo/my-images...ectrical8.jpg/
http://imageshack.us/photo/my-images...ectrical4.jpg/
Old 05-17-2017, 01:26 PM   #33
Rewards Points: 24
Re: 320Amp double lug meter - (2) 200amp panels
Sorry to dig up an old thread here..
We are putting in same double lugged 320 meter base here in Florida, one 200 amp service panel stubbed right next to meter and another existing garage meter that is being fed directly from meter to underground riser to garage panel.
The usual inspector seems to be on vacation and I just got inspection which we failed as the inspector noted needs disconnects grouped and garage main panel to become sub panel. This would require me to put the 80' of current SER and rerun extra conductor for ground which is alot of work.
My electrician says since the feed is underground and never enters the building that we should be ok with the way we have it. Can anyone else clarify this currently with NEC. Inspector notes said code though he did not reference a section, and I don't want to get on his bad side by arguing. May just wait until other inspector gets back from vacation or should I just do it the way the inspector interprets it?
cenfl is offline   Reply With Quote
Old 05-17-2017, 03:36 PM   #34
Licensed electrician
Rewards Points: 1,778
The disconnects do need to be grouped. You will need a disconnect next to the meter to feed the garage.
SER cannot be used underground.
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 09:54 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 06:35 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Code on supplying breaker panels spebby Electrical 10 11-01-2007 08:28 PM
100amps meter with 200amp breaker box? Snooker Electrical 3 04-15-2007 01:39 PM
