320a Meter: Two 200a Panels? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 06:51 PM   #16
Originally Posted by nap View Post
small squarish were 100 amp and a bit taller rectangle is 200 amp. The 320 is a really good sized tin can.
and to having no main: that has been a requirement for a considerable time. If you do not have a main, then either your install is very very old (although I don't know how old it would have to be to not have a main disco. at least 60 years though I believe. not sure if no main was ever legally acceptable though), it was an illegal install when installed, or it was changed to an illegal installation.
House was built in '64 but the label shows work done in '71.
Kinda' sounds like 100A service.
Maybe the county has a record of this. Or PoCo?
Old 09-15-2009, 06:51 PM   #17
zpm
yeah, right
Originally Posted by Yoyizit View Post
How do you know the amp rating of the meter?
I don't see it here
http://en.wikipedia.org/wiki/File:Electrical_meter.jpg
CL 200 - 200 amps.
But that's just the rating of the meter, not necessarily the service.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 09-15-2009, 07:23 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by zpm View Post
CL 200 - 200 amps.
wow! I hadn't even noticed. I don't think I have ever seen a 200 amp round meter base.
and as zpm states, just because the meter is rated for 200 amps does not mean the service is a 200 amp service. That just means the meter will handle a 200 amp service.
So, yoyizit, you say you have no main breaker. Explain what you do have. You may actually have a main and not realize it. Often, with the old split bus panels, there were 2 mains (up to 6 is legal). One for the upper (240 volt section) and one for the lower (120 volt section).
what is the make and model of your panel?
Old 09-15-2009, 07:26 PM   #19
For the photo I will post, you need the cover removed?
Old 09-15-2009, 10:00 PM   #20
nap
You talking to me?
nap's Avatar
that would be good but also, if there is any labeling, put that up as well.
Old 09-17-2009, 08:46 AM   #21
There is a 50A CB that shuts off all the 15A and 20A CBs below.
The incoming cable is 0.533" in dia., including the insulation.
Old 09-17-2009, 09:11 AM   #22
Licensed electrician
Rewards Points: 1,892
That is a split-buss panel. The 6 breakers at the top will cut the power in place of todays 1 main breaker.
Look to see a size on the SE cable either above the panel or near the socket.
Old 09-17-2009, 11:13 AM   #23
Yes, because one pole of that 50A breaker killed the power to half the house and I didn't notice that the one handle was slightly more "off" than the other handle. Took me two hours to figure out what happened and to reassure the wife.
No labels on the wire, but . . .
subtracting 1/16" twice from the 0.533" gives me 0.408" for the conductor diameter so I figure the wire is 000.
200A service?
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
200A Upgrade - Meter Socket Location Question bjones Electrical 2 11-12-2007 03:03 PM
