Old 09-18-2010, 05:26 PM   #1
30amps on 12awg wire?
apparently it can be done to code...
http://stuff.r-type.ca/power/1.jpg
http://stuff.r-type.ca/power/2.jpg
sorry for the picture quality of the second image, camera is rather ****ty
RTypeEman is offline   Reply With Quote
Old 09-18-2010, 06:05 PM   #2
yeah, i seem to remember the ampacity table 310-16 showing 30 amps for copper with cetain insulations if kept under 90 deg C, and in certain installations (e.g. open air, fewer then 3 current carrying cunductors bundled, etc.) anyway, we use the lowest 20 amp capability to be safe.
TimPa is offline   Reply With Quote
Old 09-18-2010, 06:13 PM   #3
Master Electrician
Certain motor and HVAC applications allow larger breakers for lower ampacity wire.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
J. V. (09-19-2010)
Old 09-18-2010, 06:36 PM   #4
nap
You talking to me?
nap's Avatar
Since you are in Canada, is that drawing using Canadian codes. Most of the info you get as general info on this site will be based on the NEC. I, personally, have no idea about what is acceptable in Canada.
and as bricc stated, there are exception for certain uses that allow even a larger breaker than a 30 amp with #12 wire but those are special uses, not general uses.
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 01:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
