30amp Sub Panel For Shed?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 07:28 PM   #1
30amp sub panel for shed??
I have a 125A main panel in my home and i want to put power to my shed. well a 30A sub panel be enough? i want a circuit of lights 15A,and a 20A circuit for plugs, and a furnace thats 20A, well a 30 amp braker sub panel be enough or should i use a 60A??
dion11 is offline   Reply With Quote
Old 11-09-2010, 07:33 PM   #2
How many lights are are you putting up and what type of things will you be plugging into those outlets?
lordlondis is offline   Reply With Quote
Old 11-09-2010, 07:44 PM   #3
7 lights, 6 plugs wanna use 20amp cause of power tools but can probley use 15amp plugs and the furnace uses 20amps
Old 11-09-2010, 07:48 PM   #4
You might start to have problems if you have the lights on and the furnace running while using a power tool. You ae better off going with the 60 amp, this way you can always expand a little later on.
Old 11-09-2010, 07:49 PM   #5
With a furnace using 20a possible out of the 30a I'd run a 60a sub
What kind of furnace ?
Actually....20a @ 120v for the furnace - that's not too bad
Unless its electric & using 240v ?
I know my boiler is on a 20a & uses far less power then that
Old 11-09-2010, 07:50 PM   #6
yea thats what was thinkin, thanks for your help bud
Old 11-10-2010, 12:14 AM   #7
Rewards Points: 150
Are we talking about a 120V subpanel? Why? One more wire!
30A @ 240V? That's PLENTY for lights, one 120V 20A 'receptacles' circuit, and a furnace. Again, this is assuming the furnace is not full-electric (ie, burns oil or gas or some other non-electrical fuel).
I'm all in favor of the 60A, but let's make it quite clear that it's desirable, but NOT necessary!
emolatur is offline   Reply With Quote
Old 11-10-2010, 08:02 AM   #8
Just call me Andrew
Rewards Points: 1,020
If his subpanel has 240v that does not help with the load unless the devices are also 240v. His lights and outlets are definitely not. That being said, I'd run a 60A subpanel.
Dion, how long is the run? I bet the cost difference won't be that great.
Andrew
secutanudu is online now   Reply With Quote
Old 11-10-2010, 10:11 AM   #9
Rewards Points: 150
Wrong.
30A @ 240V is TWO SEPERATE 120V hots, EACH having 30A available, for 60A total.
Old 11-10-2010, 10:47 AM   #10
Just call me Andrew
Originally Posted by emolatur View Post
Wrong.
I respectfully disagree. A double-pole 30A breaker will trip if EITHER leg pulls more than 30A (as per the trip curve).
Andrew
Old 11-10-2010, 12:05 PM   #11
Rewards Points: 330
article 230.79 (b) (d) 60 amp min...beacause you have more than two two-wire ckts...
oleguy74 is offline   Reply With Quote
Old 11-10-2010, 02:08 PM   #12
nevermind you are right
Old 11-10-2010, 03:27 PM   #13
Electrical Contractor
jbfan's Avatar
Rewards Points: 414
Service disconnecting means needs to be rated for 60 amps, but the circuit can be any size under that!
jbfan is online now   Reply With Quote
Old 11-10-2010, 03:54 PM   #14
Rewards Points: 330
rating of service disconnecting means:the service disconnection means shall have a rating not less than the load to be carried,determined in accordance with article 220.in no case shall the rating be lower than specified in art.230.79(a)(b)(c) or (d).
Old 11-10-2010, 04:07 PM   #15
jbfan's Avatar
Rewards Points: 414
And the point is?
230.79(a) through (d) are talking about service disconnecting means
You can have any size service to an outbuilding you desire as long as the disconnting means are equal to or larger.
I could not charge a customer for a 60 amp service to a shed, when all that is needed is 30 amps or less.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
30amp slim design breaker or sub panel? Which one? Boyd Electrical 10 09-25-2008 02:36 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
