30amp Slim Design Breaker Or Sub Panel? Which One? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2008, 03:54 PM   #1
30amp slim design breaker or sub panel? Which one?
I stumbled across this site by the grace of google. I checked similar sites, but this one seems the most informative. Great stuff!
My immediate needs are to run a 220v circuit to my garage to feed an air compressor. In the future, I eventually want to add a welder and dedicated circuits for miscellaneous shop tools. In other houses that I've lived in, I've been able to add a 220v circuit, but I've always been blessed with working with a 200amp main panel that had plenty of room. However, the house we recently moved in to has a 150amp main panel that only has two slots left - one on each side at the bottom(see pics).
Do they make a slim-design 30amp breaker to fit in one of the slots? If not,or for future reference, how would I wire the sub panel in to this "at capacity" main panel?
Pics are blurry, I apologize, can't figure the wife's DSLR camera out.
Boyd is offline   Reply With Quote
Old 09-23-2008, 04:40 PM   #2
Electrician
Not to pick the panel apart, but every wire coming in 1 knockout is a violation, but anyway, Looks like that panel is pretty full, You would really have to move some stuff around and buy some more twins to make it work, I would opt for a sub-panel.
chris75 is offline   Reply With Quote
Old 09-23-2008, 04:44 PM   #3
Damn.
I HATE when they do that!
They SHOULD have put a 40 space panel in.
Move #18, (bottom right breaker) to #19 (bottom left space)This will give you two spaces at the bottom right.
Run a 60 amp circuit/subpanel to the garage with 6/3/wg cable.
Run your compessor/shop tools off the garage sub.
220/221 is offline   Reply With Quote
Old 09-23-2008, 05:20 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
I agree with 220/221.
Old 09-23-2008, 06:22 PM   #5
Electrician
I do too, to be honest, I posted premature.
Old 09-23-2008, 10:55 PM   #6
That's one of the reasons I wanted to include pics, the inside of my panel just didn't look "right" for some reason.
Thanks for the suggestion 220/221. Looks like I'll be having some fun this weekend!! I'll make sure and report back with the results.
Old 09-23-2008, 11:07 PM   #7
" Euro " electrician
frenchelectrican's Avatar
I will agree with the guys here and also this is not a stanard HOM series panel box due you have riser pipe on the left.
There is not many place used the riser pipes like that.
{ two place it will ring the bell typically condo's or apartments { in some spots } }
Merci,Marc
Old 09-23-2008, 11:43 PM   #8
Idiot Emeritus
Rewards Points: 1,492
This is actually simpler than it looks. This panel is a square D homeline.
Notice the breaker on the top left. It is a combination breaker that has two single pole breakers on the outside, and a two pole in the middle.
It looks like the breaker on the bottom right is a 15. If so, you can get a combo breaker that has 15's on the outside, and a 30 amp two pole in the middle.
Easy fix, plus you get a spare 15.
220's idea for a 60 amp sub-panel is likely best in the long run though.
Rob
micromind is offline   Reply With Quote
Old 09-24-2008, 06:25 AM   #9
jbfan's Avatar
Rewards Points: 382
Merci,Marc
Marc: That looks like it is outside, and we know someone here that installs most of their panels that way.
Isn't that right 220/221?
Old 09-24-2008, 08:02 PM   #10
That's the way we roll
Old 09-25-2008, 02:36 PM   #11
Im curious but, whats that white thing stapled under the eave, it looks like indoor romex from before they color coded the cables. Or at least extension cord....
rgsgww is offline   Reply With Quote
Circuit Breaker Panel Height? helpless handyman Electrical 25 02-24-2014 03:06 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
