30amp RV Outdoor Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2009, 05:35 PM   #1
30amp RV outdoor outlet
I am installing a 30amp RV outlet 100ft from my main panel using 3 #8 wire
my question is I want put a regular 15 amp outlet that would feed from
30 amp outlet can i just pigtail #8 wire with #12 wire.
rod torres is offline   Reply With Quote
Old 05-27-2009, 05:45 PM   #2
300zx's Avatar
No you will have to pull a seperate line for rec also needs to be GFCI with inuse cover.
300zx is offline   Reply With Quote
Old 05-27-2009, 07:00 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
NO! You cannot have a 15 or 20 amp receptacle on this 30A circuit.
They do sell RV boxes with separate breakers for the 30 and 15 amp receptacles that are basically small sub-panels with built-in receptacles.
I'll try and find a link for you.
The 30A RV receptacle does NOT have to be GFI protected. In fact, good luck finding a single-pole 30 GFI breaker.
Old 05-27-2009, 07:06 PM   #4
What will work is a Midwest #U041C010 found on this page: http://catalog.geindustrial.com/data...CC=MA&Profile=
Old 05-27-2009, 07:08 PM   #5
The other alternative, and likely cheaper, is to run two separate circuits out to the pedestal. One 30A/120v and one 15 or 20A/120v. You can share one #10 ground.
Old 05-27-2009, 07:34 PM   #6
Thanks petey for the usefull info the all in one box seems the way to go
but if i decide to do 5 wires in 1 condiut 3 #8 and 2 #12 whats the proper
size of conduit? Im using #8 due to distance from the main panel 100ft and might have some voltage drop off and also the #8 wire was free from a
friend.
Old 05-27-2009, 07:51 PM   #7
I would use 1". You can get away with 3/4" but it's really not worth it. 1" will make things much easier.
Old 05-27-2009, 08:05 PM   #8
Thanxs again for the info it has been helpfull
Old 05-27-2009, 11:09 PM   #9
Rewards Points: 1,016
A little spendy methinks - but makes for a neat installation over separates.
Old 05-28-2009, 05:57 PM   #10
Same
That's the same thing 300 ZX stated but in much less wording.
He also got the gfi receptacle in there with much less wording.
SULTINI is offline   Reply With Quote
Old 05-28-2009, 06:47 PM   #11
What's you point?
Old 05-28-2009, 07:42 PM   #12
What's you point?
You're using up space on the forum that could have been his!
Old 05-29-2009, 06:55 AM   #13
My point
What's you point?
Is stop complicating the answers for DIY'ers. Take your time to read the questions and answers.
OH! I'm sorry did I offend you Speedy I am sorry. You asked.
And nobody asked you yoyizit.
Old 05-29-2009, 07:03 AM   #14
No sir, you did not offend me. Don't flatter yourself.
And don't be jealous that Yoyizit is on my side. He is a good guy.
Old 05-29-2009, 07:09 AM   #15
Rewards Points: 2,350
So, once the question has been answered by one person, no one else should corroborate? In a scan of the forum rules, I can't find that one..
30amp slim design breaker or sub panel? Which one? Boyd Electrical 10 09-25-2008 02:36 PM
