30A Circuit With A 15A Branch? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 07:57 PM   #1
analogmusicman's Avatar
Rewards Points: 560
30A circuit with a 15A branch?
here's the situation:
my master bath,which is being remodeled,is going to have this electric heater stuck in one corner. (that bathroom is mighty cold when taking a shower) this is no ordinary electric heater, it has no heating element but rather uses a couple special Sylvania light tubes to heat copper so it doesn't pull lots of current.
the question is about wiring a receptacle for it. this new receptacle,which I'll install in the wall right by the heater,will be used for nothing else. I can fish a piece of Romex right down to the storage room underneath where a 30A circuit is brought in to power the whirlpool tub. (which is hardly ever used)
can I simply add a branch circuit to that 30A circuit using #14 romex?should the outlet be GFCI? (I imagine it would have to be,right?)
tnx,
tnx,
analogmusicman is offline   Reply With Quote
Old 02-11-2011, 08:02 PM   #2
No, you can not use 14ga wire on a 30 amp circuit.
hayewe farm is offline   Reply With Quote
Old 02-11-2011, 09:46 PM   #3
Licensed electrician
Rewards Points: 1,010
Regardless of the usage of the whirlpool tub it must stay a dedicated circuit.
You cannot protect the #14 using the 30 amp breaker.
All 120 volt bathroom receptacles require GFI protection.
Old 02-11-2011, 11:33 PM   #4
Sounds like your gonna have to run a dedicated circuit to the heater from the panel , if it's 30 amps you'll need 3 wire #10 to feed it .
PJMark is offline   Reply With Quote
How to wire three switches on one circuit Abs777 Electrical 12 03-25-2010 04:15 PM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 10:07 AM
Adding a branch circuit help glover10604 Electrical 8 09-09-2008 02:40 PM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 06:32 PM
