30a 240v Air Compressor Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2006, 07:31 PM   #1
Extreme DIY'r Adk's, NY
Rewards Points: 272
30a 240v air compressor circuit
Wiring for future compressor at link below:
http://www.portercable.com/index.asp?e=547&p=4703
Before I insulate I want the circuit run to the compressors future home. I dont see much data there regarding the loads but it says 30a 240v. I know I need 10 ga cu but...
From my minimal experience... All dryers require 4 wires. Some welders require 4 wires (most do not). Ive never seen a 240 compressor require 4 wires. agree?
So do I run 10-2 and plan to use black hot, white hot and bare ground?
or do I run 10-3 and then if I only need 3 wires cap the whites and use red hot, black hot, bare ground?
The reason I ask is one for cost, but also for safety and code. I know on a 120v circuit it is illegal to ever use a white as hot at a receptacle or appliance (light). You can in a switch box or junction box and mark with tape. So in the case of 10-2 one of the whites would be hot. Is the code different for 240v because it sure seems that Ive seen this before.
thanks!
crecore is offline   Reply With Quote
Old 09-21-2006, 07:37 PM   #2
World famous jerk.
You only run the 3-wire stuff to your dryer because it is not straight 240. It's 240/120. Your compressor is straight 240, 30 amp, just like a water heater. Just run 10-2 to the compressor diconnect location, and remark the white conductor with black tape at each end. Code compliant and quite normal.
mdshunk is offline   Reply With Quote
Old 09-21-2006, 07:52 PM   #3
Rewards Points: 272
Makes sense. Many welders are also 120/240 and have a 4 prong plug so thats why they would need 3 wire+ground. I new it was "normal" enough that I had seen it... but that doesnt always mean it's according to NEC. I wish my Dad taught me more of this stuff. I picked up enough to get myself in trouble. Luckily I'm smart enough to know what I don't "know completely" and I respect electricity! Some people on this board are going to get themselves in trouble! yikes. thanks!
Converting std 220v/60hz to Single phase 240V 3-wire jryali Electrical 19 03-23-2009 11:06 PM
240v / 20.9A Heater jbclbc Electrical 15 01-19-2007 08:53 AM
Temp Power 240v outside Mike S Electrical 3 01-15-2007 04:52 PM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 05:50 PM
