300vdc Instead Of Variable On Treadmill - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 04:41 PM   #1
300vdc instead of variable on treadmill
Hi everyone first time post,
Have a treadmill which blows glass 15Amp fuse and sparks from motor as soon as
it start power to motor. Replaced fuse and blown capacitor and resistor on board (next to outlet to motor)
disconnected motor and tested voltage to motor 300vdc. Motor is rated 180vdc
permanent magnet. Cannot see any other blown items.
Any ideas could it be bridge rectifier?? or is it knackered
ashley123 is offline   Reply With Quote
Old 08-03-2011, 06:07 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Are you in the United States? What is the supply voltage for the unit?
Coastal South Carolina
Old 08-04-2011, 02:02 AM   #3
Sorry
australia our voltage is 240v ac
Old 08-04-2011, 10:48 AM   #4
Rewards Points: 240
Most treadmills I have worked on (not many) have a DC motor and 180 volts or 90 volts DC is nominal. (sounds correct). There will be a board (drive) that converts 240 volt AC to DC and the speed control adjusts the DC output from zero speed (0 volts) to full speed (180 volts). When you adjust speed on a treadmill you are telling the drive board to do it. The motor gets its power from the drive board.
If you worked on this board, you could have messed it up. Are you sure your meter is reading true 300 Volts DC and not 300 millivolts AC/DC? Whats the name brand on the drive board and what is the model number. Any numbers on this board you should post. This goes for the motor too. If you provide enough information, we can surely help. Now get to work and write all these numbers and letters down and get them posted.
J. V. is online now   Reply With Quote
The Following User Says Thank You to J. V. For This Useful Post:
ashley123 (08-09-2011)
Old 08-04-2011, 11:26 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,990
You can't measure the voltage to the motor with the motor disconnected. The motor speed controller uses an SCR (usually) to chop the power to the motor to control speed, and the motor itself plays an important role in this. With it disconnected, the speed controller will not function and you'll read the full DC bus voltage all the time.
Based on the type of failure you have, though, I'd guess the speed controller is bad, and isn't chopping the voltage at all. This may be fixable by replacing the switching device (usually an SCR or a bank of them), or it may be more complicated than that. This is well beyond the scope of normal DIY electrical work, but if you're already replacing capacitors and other board-level components then maybe you can handle it.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 08-04-2011, 04:28 PM   #6
Thanks everyone
the treadmill is a jazfit-e2
there is some info on the board
D.er: NBCQF (up the top)
05.9.14
www.justsports.com.cn (at the bottom right)
Old 08-04-2011, 04:43 PM   #7
Thanks everyone
05.9.14
www.justsports.com.cn (at the bottom right)[/QUOTE]
Old 08-09-2011, 03:43 AM   #8
Thanks guys
Replaced the igbt and everything works.
The Following User Says Thank You to ashley123 For This Useful Post:
mpoulton (08-09-2011)
Variable Speed Vs " Multi - Speed " alecmcmahon HVAC 15 04-14-2011 03:06 PM
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 12:07 PM
Treadmill outlet TANC Electrical 3 02-02-2010 09:53 PM
Variable speed Blower konqwest HVAC 4 12-01-2009 04:45 AM
Only one outlet will power treadmill? archer75 Electrical 17 05-05-2009 12:20 AM
