300A Breaker Box? Is This An Odd Ball? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 07:14 PM   #1
Rewards Points: 234
300A breaker box? Is this an odd ball?
We are putting some load charts together for a new building and determined we will likely need/request 600A/240V/1P. We originally were looking at 400A which would be an easy enough install with dual 4/0 triplex pulls going to 200A panels. Additional power will be required for an additional sub structure and lighting.
In looking to run another 200A, it might be more cost effective to run dual 300A panels but have never seen them. Also, it seems that 200A panels are much cheaper and more abundant.
The run will be about 200ft so considerations must be made regarding 2 or 3 pulls. There would of course be no concern in installing larger than required panels if 400A is more abundant.
Also trying to consider the wire price differences between the 2 and 3 pulls.
viper is offline   Reply With Quote
Old 12-28-2011, 07:20 PM   #2
Electrical Contractor
kbsparky's Avatar
This is beyond the scope of a D-I-Y forum.
You should consult with a master electrician or electrical engineer for such projects.
-KB
Old 12-28-2011, 07:33 PM   #3
Rewards Points: 13,724
Something needing that much power would need it's own supply.
I agree 100% on this one. Hire an electician, not a DIY job.
Old 12-28-2011, 07:37 PM   #4
Rewards Points: 234
Yes, we are having a pad transformer set for this application. I apologize if I put too much into my post. I should have just asked about the breaker panels since that is ultimately the only question I have. 300A panels, are they an odd ball or available and if so, are they priced well outside the typical 200A panels?
Old 12-28-2011, 08:09 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
There is no such thing as a 300A panel.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (12-29-2011)
Old 12-28-2011, 08:13 PM   #6
Rewards Points: 234
Also in comparing wire price and preferred layout, it would seem a 400A and 200A panel will be the way to go. Have not pulled 600 wire in a LONG time so I hope I am ready for that workout.
I have seen 300A panels but cannot remember if they were 3p or 1p.
Old 12-28-2011, 09:13 PM   #7
Electrician
Rewards Points: 794
The way to go is to hire an electrician and let him worry about it. This is a DIY site, I can't see you putting a 600A service in your house.
The easiest way is to get a main distrubition panel with a 600A main breaker, and then break off there to what ever panels you have, but your electrician will let you know what is the best way to go.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
Old 12-29-2011, 01:30 AM   #8
Julius793's Avatar
300a is made but you will probably pay alot and it's hard to find, I would go with 400a and a 200a
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-29-2011, 05:28 AM   #9
Sparky
Rewards Points: 510
you can find a '300A' Main breaker panel, but the buss is still 400A rated in most cases
Techy is offline   Reply With Quote
The Following 2 Users Say Thank You to Techy For This Useful Post:
frenchelectrican (12-29-2011), Speedy Petey (12-29-2011)
AFCI Breaker Keeps Tripping Muinchja Electrical 30 08-25-2011 04:54 PM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 06:47 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
