30 Amp Service In Camper - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2014, 04:55 PM   #1
Rewards Points: 722
30 amp service in Camper
I have a neighbor that has a small pop-up camper and he's trying to wire it for basic electricity. He bought a 30amp RV cord w/ male plug so that he can plug into service at a campground outlet. The other end is going into a very small 4 circuit 2 pole breaker box. Since his power isn't 220, the thought is to pigtail off the Hot line and feed both sides of the box. Both sides seem to be independent of each other and there aren't any 220 breakers installed. Is this a problem?
Then there is only a single bus bar, so the neutral is going to that. This bus bar appears to be isolated from the metal box and there is a bonding screw included if needed.
I'm assuming to complete the installation, there needs to be a 2nd buss bar added directly to the enclosure and that all grounds need to go to that and that the bonding screw shouldn't be used. Am I correct in this logic?
I feel I have a very strong grasp of electrical basics, but this is getting out of my realm, but I want to help him create a safe setup.
The current wiring has the neutral and the ground wire both going to the single buss bar, but it trips the GFCI that he is plugging into. I'm guessing it's due to the ground/neutral being bonded.
I am curious though why that might happen as I know it is sometimes done in sup-panels, though I realize it's not very safe.
Thanks for any help!
Master Brian is offline   Reply With Quote
Old 06-02-2014, 05:07 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
Mine in RED.
No, but you need to jump the two line side lugs.
Yes, exactly.
Again, yes, exactly. This is why you need the separate ground bar and isolated neutral.
No, it's not done in sub-panels. The requirement to separate neutrals and grounds in all sub-panels is quite old now.
Speedy Petey is online now   Reply With Quote
Old 06-02-2014, 05:10 PM   #3
Rewards Points: 332
Why not just install a "power converter"? That way he can have 12v accessories as well. If he's interested, I have one I'll give away for the cost of shipping. Feel free to PM me and I can provide more info.
sgip2000 is offline   Reply With Quote
Old 06-02-2014, 05:13 PM   #4
Rewards Points: 1,832
I agree with Speedy Petey, however, be careful how you jump the buss bars. Many lugs aren't rated for 2 conductors. A Polaris connector would be the best option or just using every other space in a larger box. Since this is a 30amp and at least a #10 gauge wire you could get away with wire nuts rated for 3 #10s.
Jump-start is offline   Reply With Quote
Old 06-02-2014, 05:32 PM   #5
As most know here I am pretty strict as far as code goes, but in a case like this I'd have no problem putting two #10's under the line lug. Especially if it was stranded.
Old 06-02-2014, 05:47 PM   #6
But still, if its not listed as such why open the door to liability?
Old 06-02-2014, 06:07 PM   #7
Rewards Points: 722
I told him to maybe think of a wire nut to create the "jumped" connection to hot, but right now it is #10 stranded, from cord, and a short length of #10 solid strand wire under the lug. Basically, it was a 'this should work, but lets test' type of scenario.
As for the ground and neutral being isolated in a sub panel, I realize that's the way it's 'supposed' to be done and that it's been code for some time, but in his very old garage that isn't the way it was done. Myself and someone else have told him to get it fixed, but he says it's been that way for years.....maybe some day we'll get it changed. But that's another discussion for another day!
I had a minute and actually ran down there a few minutes ago and unhooked the ground wires from the neutral buss and of course it worked. Now he just needs to grab another one for the ground!
I'll ask him about a power converter, not sure what his intentions are on that. He's talked about adding a battery or two for 12v power.
Old 06-02-2014, 06:19 PM   #8
You will need a ground bar. Theses are sold separately at home centers and come in various sizes. Just find one that will fit in the sub panel and have all ground connected to this and your set. Leave the bonding screw out of the neutral bar.
Jumping the lug will work, but its not the best since it is something that may or may not fail down the road. The panel cover should have a label that will tell you how many wires under a lug in question.
The Following User Says Thank You to Jump-start For This Useful Post:
Master Brian (06-02-2014)
Old 06-02-2014, 08:43 PM   #9
With stranded wire tell me what bad will come of it?
It's like the "#14 on a 20A breaker will burn your house down" mantra. We all know it's not remotely true, but we have to play that game.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
HouseHelper (06-02-2014), jbfan (06-02-2014)
Old 06-02-2014, 09:12 PM   #10
Manufacturers list their lugs for a reason. When they design any piece of equipment its engineered around an intended purpose in mind. If the label lists only 1 conductor its easy to just do so then to gamble what might happen down the road.
And #14 will not spontaneously combust on a 20 amp breaker, but does that mean we can ignore the NEC rules and wire all 20 amp circuits with #14? Would I like to from a cost standpoint? You bet! Everyday. But to knowingly violate the NEC making up what rules are convenient for you is not a good idea.
Yes its stranded, but if I had to guess one is 2 set of strands side by side the other a larger gauge wire but still only 1 set in a cylindrical. The lug could grab one set of strands more than the other. But it doesn't matter, the engineers have done the thinking on that one already.
Im not trying to give you a hard time but I know usage and listing comes up on some double taps.
Old 06-03-2014, 06:44 AM   #11
I am FULLY aware of all this. I was not looking for an explanation of what is required or why.
And I never said I make up my own rules. I was merely stating an opinion. I had a feeling this was not a good idea from the start.
The Following User Says Thank You to Speedy Petey For This Useful Post:
MTN REMODEL LLC (06-05-2014)
Old 06-03-2014, 08:57 AM   #12
Rewards Points: 3,256
...The current wiring has the neutral and the ground wire both going to the single buss bar, but it trips the GFCI that he is plugging into. I'm guessing it's due to the ground/neutral being bonded.
Is this GFCI in the garage panel that the trailer is plugged into? I would think it's more of a case where the trailer neutral and ground is bonded together. If it isn't, I don't see how this GFCI could be tripping. When you removed the panel ground, you also took away the trailer ground path and all of the current returned on the neutral like it should.
zappa is offline   Reply With Quote
Old 06-03-2014, 09:03 AM   #13
If it will fit in the lug, you could use a sleeve on the stranded #10's.
Old 06-04-2014, 02:31 PM   #14
Rewards Points: 722
Yes, it was plugged into a GFCI wired to the garage panel. That panel has the neutral and ground on the same buss bar.
He told me he picked up a buss bar this morning to isolate the neutral and ground wires in the trailer panel.
Moving electric service entrance to detached garage WillK Electrical 7 10-05-2011 11:13 PM
rewire and new service entrance wire dghowery Electrical 4 10-13-2010 09:31 AM
"Moving" service entrance WillK Electrical 4 09-29-2010 02:04 PM
How to tell Service amperage?? Buckley Electrical 2 06-06-2009 06:42 PM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 11:10 AM
