30 Amp Outlet For RV - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 04:05 PM   #1
30 amp outlet for RV
I just bought a travel trailer and will need a 30 AMP outlet on the outside of my house. Here is my current setup - I have a 200 AMP service panel and a 50 AMP dual pole breaker that leads to an outdoor subpanel for my pool. Inside that panel are two 20 AMP breakers - one for the pool filter and one that is connected to a GFI outlet that i use to power tools like my electric leaf blower, etc.
Can I remove the second 20 amp breaker and replace it with a 30 AMP single pole breaker and run new #10 wire and replace the GFI receptacle with a 30 AMP receptacle for my RV? I had previously run a new dedicated line outside to another side of my house better suited for the blower and Christmas lights so i no longer need the one i use now.
Does that make sense or should i just install a new 30 amp breaker in my main panel and go through the hassle of running a new line outside and installing a new box? I am hoping to just use the existing.
Thanks for the help!
khorrocks is offline   Reply With Quote
Old 07-10-2008, 04:14 PM   #2
Licensed Pro
Does the outdoor subpanel only have space for two breakers? Most will handle at least four, so I would just add a third and run 10/2 to the RV receptacle, keeping the 20A circuit.
Old 07-10-2008, 04:20 PM   #3
I suppose it does have room for more...hadn't considered that. For some reason I had "50 amps" stuck in my head so "20" plus "30" = "50"
thanks....that would definitely be the easiest thing
Old 07-10-2008, 04:33 PM   #4
Electrician
Adding the breakers up is not how it works. but looks like you figured that out.
chris75 is offline   Reply With Quote
Old 07-10-2008, 04:34 PM   #5
Right...I just can't draw more than 50 amps at the same time...
Shouldn't be aproblem there. Thanks again.
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
