30 Amp Outlet On 50 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 06:23 PM   #1
30 amp outlet on 50 amp breaker
I was wondering if it is possible to run a 30 amp outlet on a 50 amp breaker.i have a 50 amp breaker and want to extend a line thats already ran but the 50 amp outlet doesnt match the 240 plug i have.thanks for any help.
ptaatp is offline   Reply With Quote
Old 02-21-2011, 07:00 PM   #2
Rewards Points: 1,574
Yes, if you replace the 50 amp breaker with a 30 amp breaker.
bob22 is offline   Reply With Quote
Old 02-22-2011, 12:24 AM   #3
" Euro " electrician
frenchelectrican's Avatar
What this 30 amp receptale is used for the dryer or compressor or other use?? it will make the diffrence on the codewise when you move it at the diffrent location.
Merci.
Marc
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 07:07 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 02:04 AM
Kitchen outlet breaker simma Electrical 3 02-28-2007 06:50 PM
