Old 05-24-2010, 08:19 PM   #1
30 amp gfi breaker
Ok, Ok,....I know I have been asking alot of questions on this temp power pole,.....The reason i am doing this myself is because I haven't hired an electrical sub to wire my house yet....still working on getting permit/power.....I am NOT going to wire house,...just trying to get this pole installed so i can get power and move forward. You can see from pic I have a 30 amp receptacle for a camper I will be staying in while building... 1)Does this 30 amp box look like it will be ok for NEC code? And I am having a hard time finding a 30 amp gfi breaker for this. 2) It is my understanding I need one for code? 3) If I don't use up all the breaker spaces in breaker box and there is an open space in cover, (yes I have cover) is this ok?
Thanks as always.
ugabulldog is offline   Reply With Quote
Old 05-24-2010, 08:31 PM   #2
Master Electrician
30 amp gfi breaker
That appears to me to be a 277 volt receptacle.
brric is offline   Reply With Quote
Old 05-24-2010, 09:02 PM   #3
30 amp gfi breaker
No Ground Rods! Ok,I see maybe a bare wire,#6.
bobelectric is online now   Reply With Quote
Old 05-24-2010, 09:48 PM   #4
" Euro " electrician
frenchelectrican's Avatar
30 amp gfi breaker
Nope that is Nema 5-30TT { travel trailer plug format }
Voila here the photo it will show more clear
Merci,Marc
Old 05-24-2010, 09:52 PM   #5
Master Electrician
30 amp gfi breaker
Merci,Marc
Thanks, Marc.
Old 05-24-2010, 10:18 PM   #6
30 amp gfi breaker
Brric.,
Here is the real deal of 277V 30A repcetale.,
Merci,Marc
Old 05-24-2010, 10:22 PM   #7
Master Electrician
30 amp gfi breaker
Looks just like a 7-15R to me.
Old 05-25-2010, 06:34 PM   #8
Phoenix
30 amp gfi breaker
Single pole 30amp GFI breaker ? I've never seen one but im sure they are out there. You may have to go to a supply house & special order one.
I didnt even know they were a requirement for temporary power.
Axecutioner-B is offline   Reply With Quote
Old 05-25-2010, 07:41 PM   #9
Licensed electrician
30 amp gfi breaker
Not sure why you are installing a 30 amp receptacle. Power tools like saws and drills will only need a 20 amp maximum circuit.
Old 05-25-2010, 07:50 PM   #10
30 amp gfi breaker
Jim.,
In case you did not catch the OP mention he will bring the camper so he will need 5-30TT receptale anyway but for anything else yeah that right you will need max of 20 amp circuit.
Merci,Marc
Old 05-25-2010, 08:54 PM   #11
30 amp gfi breaker
That explains it, thanks Marc.
Only 15 and 20 amp exterior receptacles require the GFI protection.
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 08:48 PM
