30 Amp 220 Volt To 110 Volt - Electrical - DIY Chatroom Home Improvement Forum
Old 08-17-2012, 09:17 AM   #1
30 amp 220 volt to 110 volt
I'm drawing a blank in my mind. Not thinking straight.
My RV is 30 amp 110volt. Want to run off my generator 30amp 220 volt. Is there an adapter one can buy to convert the 220 volt to 110 volt? I know generators have to have balanced draw on the fields.
Gregad511 is offline   Reply With Quote
Old 08-17-2012, 09:58 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
What type receptacles( configuration and amperage) do you have on your generator? What is the wattage of your generator.
If the generator puts out both 120 and 240, you will only be able to hook the RV up to the 120 side. You will not be able to balance the load.
A RV dog bone adapter will connect your 30 amp male RV plug to connect to a 15/20 amp receptacle on your gen set.
Available at Walmart, Harbor Freight, Northern Tool or any RV dealer.
Coastal South Carolina
Old 08-17-2012, 11:25 AM   #3
Rewards Points: 3,130
As noted, unless your generator has a 120V receptacle, you're out of luck. And even if it does, it's probably only a 20-amp circuit. You "might" be able to run the air conditioner. If you want to spend some money, there are generators that have an RV receptacle. The ones quiet enough for use in a campground are about $1,000 or more, but I bought a 3KW Champion from Lowe's for around $350.
Old 08-17-2012, 05:55 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,096
As you have already summerised its not just a matter of
an adaptor(which are easily made), its also a matter of
balancing the load, most gennys would not like such an imbalance !
Have you checked the genny ? to see if it can be reconfigured
for 120v operation ? some can !
dmxtothemax is offline   Reply With Quote
Old 08-18-2012, 06:39 AM   #5
Rewards Points: 1,418
Connect the RV power cord to one 120 volt generator receptacle. If needed, use an adapter with a 30 amp female receptacle for the RV cord and 15 or 20 amp male plug to go into the generator receptacle.
Connect a plain extension cord (the orange variety of at least 14 gauge) to the other generator 120 volt receptacle, and string that through a window of the RV. Inside the RV connect a power strip to this. Plug most of your cord and plug lamps and appliances into this while the hard wired appliances and lights are powered by the RV cord. This will more or less balance the load for the generator and also hold down the load on the 30 amp RV cord going through the 20 amp generator receptacle.
Old 08-18-2012, 07:11 AM   #6
Good plan, but RVs usually don't have any "cord and plug" appliances. None of mine ever has. The only thing I could plug into a power strip would be the television. And as I said, depending on its BTU rating, the OP might not be able to run the air conditioner.
24 volt AC wiring in same conduit as 220 volt single phase and in same outdoor enclosure as 220 v silgle phase and 3 phase arbailey Electrical 5 05-24-2012 09:43 PM
12 Volt lighting AC or DC johnr9q Electrical 20 11-21-2010 02:12 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 07:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 12:37 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
