3 Wire Romex For Single Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 09:46 PM   #1
3 wire romex for single switch
I have a light switch plug combo over my bath sink. I pulled the combo switch (it's not a GFCI) intending to place a single switch in it's place. The red connected to the plug, the black to the switch with a common white (red and black are hot). Do I pigtail the black and red together for the single switch feed? Thanks.
jraf is offline   Reply With Quote
Old 04-05-2010, 10:06 PM   #2
Master Electrician
Rewards Points: 3,768
More than likey the red and the black go to the new switch with the white wire nutted and buried in the box.
brric is offline   Reply With Quote
Old 04-05-2010, 10:23 PM   #3
Master Electrician
which of the wires had the tab between them. It's possible the the red is a switch leg and the black fed both the switch and the plug. This scenario to me seems most likely if there's only one three wire in the box. If they had feed the plug with the red and the switch with the black then they would have needed another wire to act as a switch leg being as the white was needed as a neutral.
andrew79 is offline   Reply With Quote
Old 04-06-2010, 08:16 AM   #4
Rewards Points: 1,448
The red connected to the plug, the black to the switch with a common white (red and black are hot)..
The red is the power supply for the plug (receptacle) and also for the switch.
The black goes to the light that the switch controls.
The white is the neutral needed for the plug. Since you are installing a plain switch, the white is not needed any more. Tape or wire-nut the end all by itself and curl that wire up uncut in case the next owner of the house wants to put a plug there again.
Old 04-06-2010, 09:46 PM   #5
Thanks for the info. Worked out great. JF
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
2 lights from 1 switch, w/ no wire directly from light1 to light2 conradA Electrical 4 03-31-2010 11:25 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
New stove switch doesn't have place for earth wire warrickvdb Electrical 1 05-08-2008 01:18 PM
Overhead light w/ switch and 3 recept. how to wire? twilightcall Electrical 8 01-07-2008 05:27 PM
